扫一扫,分享给好友
在Vivado 2013.2上生成了ten_gig_eth_pcs_pma IP的许可证后,我就可以生成IP了。
但是,合成失败,并显示以下消息。 INFO:[合成器8-256]进行合成模块 'ten_gig_eth_pcs_pma_v3_0_ten_gig_eth_pcs_pma_v7_gth_kr_top'(209#362)[/local_disk/***hutada/FPGA/gtcores/10g/project_1.srcs/sources_1/ip/ten_gig_eth_pcs_pma_0/ten_gig_eth_pcs_pma_v3_0/ten_gig_eth_pcs_pma_v3_0_ten_gig_eth_pcs_pma_v7_gth_kr_top.v:120]Fatal 错误。 安全IP的许可证检查失败。 退出合成。 我还需要一个合成许可吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Having generated the License for ten_gig_eth_pcs_pma IP on Vivado 2013.2, i am able to generate the IP. However, the synthesis fails with below message. INFO: [Synth 8-256] done synthesizing module 'ten_gig_eth_pcs_pma_v3_0_ten_gig_eth_pcs_pma_v7_gth_kr_top' (209#362) [/local_disk/***hutada/fpga/gtcores/10g/project_1.srcs/sources_1/ip/ten_gig_eth_pcs_pma_0/ten_gig_eth_pcs_pma_v3_0/ten_gig_eth_pcs_pma_v3_0_ten_gig_eth_pcs_pma_v7_gth_kr_top.v:120] Fatal Error. License Check failed for secure IP. Exiting Synthesis. Do i need one more license for synthesis? Thanks. |
16个回答
嗨萨钦,
如果核心和工具的许可证位于不同的服务器上,则存在已知问题。 看看下面的AR。 http://www.xilinx.com/support/answers/52062.htm 让我知道它是否有帮助,或者您的环境是否不同。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Sachin, There is known issue if the licenses for the core and the tool are on different servers. Have a look at the below AR. http://www.xilinx.com/support/answers/52062.htm Let me know if it helps or if your environment is different. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
嗨Sachin,如果你有工具和IP的节点锁定许可证,那么将许可证复制到/.Xilinx/ folderThanks
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Sachin, If you have node-locked licenses for tool and IP, then copy the licenses to the Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
IP的许可证文件已存在于同一文件夹中。
查看快照,它说许可证可用。 不应该有合成错误。 以上来自于谷歌翻译 以下为原文 The License file for IP is already present in the same folder. See the snapshot , it says License available. There shouldnt be the synthesis error. |
嗨萨钦,
好的,所以你有一个IP的节点锁定许可证。 那么Vivado工具许可证,这也是一个节点锁定或浮动许可证。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Sachin, Ok,so you are having a node locked license for the IP. What about the Vivado Tool license,Is this also a node locked or a floating License. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
嗨,
你能附上xinfo文件吗? 从C: Xilinx Vivado 2013.2 ids_lite ISE bin nt64运行xinfo.exe 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you please attach xinfo file? Run xinfo.exe from C:XilinxVivado2013.2ids_liteISEbinnt64 Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
你好,
xinfo文件附加 复制自/tools/xilinx/Xilinx_Vivado_Lin_2013.2_0616_1/Vivado/2013.2/ids_lite/ISE/bin/lin64/xinfo xinfo 21 KB 以上来自于谷歌翻译 以下为原文 Hello, xinfo file attached copied from /tools/xilinx/Xilinx_Vivado_Lin_2013.2_0616_1/Vivado/2013.2/ids_lite/ISE/bin/lin64/xinfo |
您需要从命令提示符运行xinfo.exe并发送生成的xinfo.txt。
xinfo.txt包含您的许可证信息。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 You need to run the xinfo.exe from command prompt and send the generated xinfo.txt. The xinfo.txt contains your license information. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我没有从任何文件中删除任何内容。
我认为我们必须改变setenv的价值 我做了回音$ LM_LICENSE_FILE 结果是什么从我删除了2100件事并且做了setenv LM_LICENSE_FILE 我认为这应该是正确的。 好的xinfo.txt附上了 xinfo.txt 419 KB 以上来自于谷歌翻译 以下为原文 I did not remove anything from any FILE. I thought we have to change the value of setenv i did echo $LM_LICENSE_FILE What ever was the result i removed 2100 thing from it and did setenv LM_LICENSE_FILE I think that should be correct. Well xinfo.txt attached |
嗨Sachin,从xinfo,我发现正在从服务器中挑选工具许可证,并且正在从机器中挑选IP许可证(即,节点锁定)。所以我也怀疑AR#56618适用于此。谢谢
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Sachin, From the xinfo, I observed that tool license is being picked from server and IP license is being picked from the machine (i.e., Node-locked). So I also suspect the AR#56618 applies here. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
好吧,即使$ LM_LICENSE_FILE中没有2100值,仍会检查浮动SW许可证。
您可以从命令行运行诊断以查询所有许可证文件。 lmutil lmdiag合成 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Well, the floating SW license is still checked even though there's no 2100 value in $LM_LICENSE_FILE. You may run diagnostic from command line to query all license files. lmutil lmdiag Synthesis ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
有了这个命令,我得到了
lmutil lmdiag Synthesislmutil - 版权所有(c)1989-2007 Macrovision Europe Ltd.和/或Macrovision Corporation。 保留所有权利.FLEXnet诊断于星期二十月二十九日23:36 ---------------------------------- -------------------许可证文件:2100@sv3.smi.local--------------------- --------------------------------“Synthesis”v2013.10,vendor:xilinxd许可证服务器:sv3.smi.local 浮动许可证到期日期:2013年12月29日TS_OK:客户端使用终端客户端时允许签出可以签出此许可证-------------------------- -------------------------------------------------- ------------------------------ 很明显,合成许可证是从2100@sv3.smi.local服务器中挑选出来的。 IP许可证是本地计算机的节点锁定。 那么我是否需要为锁定到2100@sv3.smi.local服务器的IP核心节点生成新许可证? 我不热衷于从LM_LICENSE_FILE中删除2100的原因是,由于无法获得许可,我将无法进行综合。 我的理解是否正确? 以上来自于谷歌翻译 以下为原文 With that command i get lmutil lmdiag Synthesis lmutil - Copyright (c) 1989-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved. FLEXnet diagnostics on Tue 10/29/2013 23:36 ----------------------------------------------------- License file: 2100@sv3.smi.local ----------------------------------------------------- "Synthesis" v2013.10, vendor: xilinxd License server: sv3.smi.local floating license expires: 29-dec-2013 TS_OK: Checkout permitted when client is using terminal client This license can be checked out ----------------------------------------------------- ----------------------------------------------------- So it pretty clear, the synthesis license is picked from 2100@sv3.smi.local server. And the IP license is nodelocked to local machine. So do i need to generate a new license for IP core node locked to the 2100@sv3.smi.local server? Reason i am not keen on removing 2100 from LM_LICENSE_FILE is that then i will not be able to synthesis at all due to non availabilty of license. Is my understanding correct? |
嗨萨钦,
是的,你的理解是正确的。 请不要为服务器生成IP节点锁定许可证,请按照下列步骤操作: 1.登录www.xilinx.com/getlicense 2.为您的机器生成30天评估许可证(Nodelocked) 3.将其保存在.Xilinx文件夹中 4.现在尝试在您的设计上运行综合。 如果此方法有效,则需要按照AR#56505中提到的步骤进行操作。 感谢致敬, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Sachin, Yes, your understanding is correct. Instead of generating a IP node-locked license to the server, follow these steps: 1. Login in to www.xilinx.com/getlicense 2. Generate a 30-day evaluation license to your machine (Nodelocked) 3. Save it in the .Xilinx folder 4. Now try running synthesis on your design. If this works, you need to follow the steps mentioned in the AR#56505. Thanks and regards, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,
在购买之前我已经用完了eval许可证。 因此,购买许可证并且无法将其用于IP是非常棘手的情况。 以上来自于谷歌翻译 以下为原文 Hi , i have already used up the eval license before buying one. So this is pretty tricky situation of having a purchased license and not being able to use it for an IP . |
sachinb_smachines写道:
我不热衷于从LM_LICENSE_FILE中删除2100的原因是,由于无法获得许可,我将无法进行综合。 我的理解是否正确? 除了浮动许可证,我还可以看到来自xinfo.One的另外两个合成特征来自/home/***hutada/.Xilinx/Xilinx.lic,另一个来自/home/***hutada/.Xilinx/old.lic。 后者似乎是评估许可证。 第一个看起来是一个完整的系统版许可证。 这就是为什么我建议您删除浮动许可证以使SW和IP许可证都被节点锁定。 但不知何故修改$ LM_LICENSE_FILE不会删除浮动许可证。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 sachinb_smachines wrote:Apart from the floating license, I can see additional two Synthesis features from xinfo. One is from /home/***hutada/.Xilinx/Xilinx.lic and the other is from /home/***hutada/.Xilinx/old.lic. The latter one seems to be evaluation license. The first one looks to be a full system edition license. That's why I suggest that you remove the floating license to have both SW and IP licenses to be node locked. But somehow modifying $LM_LICENSE_FILE doesn't remove the floating license. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2687 浏览 7 评论
3006 浏览 4 评论
2428 浏览 9 评论
3537 浏览 0 评论
2635 浏览 15 评论
3413浏览 1评论
830浏览 1评论
694浏览 1评论
GMT+8, 2025-7-1 10:37 , Processed in 1.613812 second(s), Total 106, Slave 90 queries .
