我在使用chipscope编译ISE(webtpack)期间遇到以下错误。
(我刚刚购买了ChipScope并安装了许可证)。 有什么想法吗? 我很欣赏这个。 错误:NgdBuild:1317 - 使用核心芯片eye_ila_v1需要ChipScopePro许可证。 以下块是核心芯片的实例:eye_ila_v1:错误:安全性:12 - 没有'xc7a200t'功能版本2013.10可用(-5),错误:NgdBuild:1316 - 试图获得ChipScopePro许可证时遇到问题。 以上来自于谷歌翻译 以下为原文 I'm having the following error during ISE (webtpack) compile with chipscope. (I have just purchased ChipScope and installed license). Is there any thoughts? I appreciate this. ERROR:NgdBuild:1317 - Using core chipscope_ila_v1 requires a ChipScopePro license. The following blocks are instances of core chipscope_ila_v1: ERROR:Security:12 - No 'xc7a200t' feature version 2013.10 was available (-5), ERROR:NgdBuild:1316 - A problem was encountered attempting to get the ChipScopePro license. |
6个回答
嗨,我没有看到xinfo文件中的工具获取任何许可证。您可以将chipscope许可证复制到c:/。xilinx位置并重新启动ISE。
检查这是否有帮助。如果以上操作不起作用,还要附加新的xinfo和许可证文件。谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, I dont see any license picked up by tool in the xinfo file. Can you copy the chipscope license to c:/.xilinx location and restart ISE. Check if this helps. Also attach the new xinfo and license files if the above does not work. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left)View solution in original post |
嗨,请查看http://www.xilinx.com/support/answers/38469.htm
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Please check http://www.xilinx.com/support/answers/38469.htm Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨,
这是哪个版本的ISE? 您是否可以附上Xinfo文件,以便我们检查是否正确接收了chipcope许可证? 要生成xinfo,请按照以下步骤操作:•从开始菜单start-> Xilinx ISE设计套件 - >附件 - > xinfo系统检查器运行Xinfo.exe。 生成Xinfo文件需要一些时间。•检查Xilinx ISE_DS文件夹中的公共文件夹中的Xinfo文件。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Which version of ISE is this? Can you attach Xinfo file so that we can check if the chipscope license is picked up properly? In order to generate xinfo, please follow the steps below: • Run Xinfo.exe from start menu start->Xilinx ISE design suite->Accessories->xinfo system checker. It takes some time to generate Xinfo file. • Check the common folder in Xilinx ISE_DS folder for Xinfo file. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
迪皮卡
感谢您的支持。 xinfo文件被附加。 ISE是14.7。 Chipscope也是最新的。 我上周买了这个。 谢谢 松野 xinfo.txt 19 KB 以上来自于谷歌翻译 以下为原文 Deepika Thank you for your support. xinfo file is attched. ISE is 14.7. Chipscope is alseo the latest too. I've purchased this last week. thank you matsuno |
检查这是否有帮助。如果以上操作不起作用,还要附加新的xinfo和许可证文件。谢谢,Deepika。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, I dont see any license picked up by tool in the xinfo file. Can you copy the chipscope license to c:/.xilinx location and restart ISE. Check if this helps. Also attach the new xinfo and license files if the above does not work. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨Deepika
感谢您的支持。 我有两个lic文件。 一个用于chipcope,另一个用于ISE。 我将这两个文件的内容组合在一起直接放在c:/ Xilinx下,然后就可以了。 这可能不是一个直接的修复方法,但它无论如何都有效。 谢谢 Nori Matsuno 以上来自于谷歌翻译 以下为原文 Hi Deepika Thank you for your support. I have two lic files. One is for chipscope, the other is for ISE. I combined the contents of these two files and put directly under c:/Xilinx directly, then it works fine. This may not be a straigt forward way to fix but it works anyway. Thank you Nori Matsuno |
2604 浏览 7 评论
2923 浏览 4 评论
2376 浏览 9 评论
3477 浏览 0 评论
2554 浏览 15 评论
3115浏览 1评论
725浏览 1评论
600浏览 1评论
GMT+8, 2025-4-21 21:41 , Processed in 2.354589 second(s), Total 86, Slave 70 queries .
