我想清理我的许可证管理器,以便它不会显示任何已过期的许可证
我过去使用的许可证。 我尝试重命名旧的许可证文件和 清除缓存,但它们仍然列出。 有没有办法清除它们? 问候, 以上来自于谷歌翻译 以下为原文 I'd like to clean up my license manager so that it doesn't show anyof the expired licenses that I have used in the past. I tried renaming the old license file and clearing the cache, but they are still listed. Is there a way to clear them out? Regards, |
9个回答
嗨,感谢您分享快照。运行xinfo并在此处共享生成的xinfo.txt文件。
我要求知道许可证文件的位置。谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Thanks for sharing a snapshot. Run the xinfo and share the generated xinfo.txt file here. I require this to know the location of license file. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨,你能在这里发布快照吗?谢谢
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Can you post a snapshot here? Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好,即使重命名和清除缓存后,如果这不起作用,那么我认为没有其他方法可以清除它。
您只能选择卸载和安装软件并再次配置许可证,但这显然是不可行的。 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Hello, Even after renaming and clearing cache if this doesn't work then i think there are no other ways to clear it. you only have an option of uninstalling and installing software and again configuring license but that is obviously not feasible.-Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好,刚刚尝试了我的结束,它在我的end.i刚刚从文件中删除.lic扩展名并清除了cachePlease尝试在你的结束。
-Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Hello , Just now tried at my end and it worked at my end. i just removed the .lic extension from the file and cleared the cache Please try at your end.-Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我要求知道许可证文件的位置。谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Thanks for sharing a snapshot. Run the xinfo and share the generated xinfo.txt file here. I require this to know the location of license file. Thanks-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
这适用于Win7机器,但不适用于我的Linux机器
它可以在哪里获取信息? 问候, 以上来自于谷歌翻译 以下为原文 This works on the Win7 machine, but not my Linux machine Where could it be picking up the information? Regards, |
谢谢。
我找到了。 我跑了xinfo,查看了文件,看到它以某种方式捡起来 我保存的原始指令的许可证。 即使我在运行许可证管理器安装它时将副本放在不同的位置。 一旦我重命名了 复制,一切都在许可证管理器中清理。 谢谢。 以上来自于谷歌翻译 以下为原文 Thanks. I found it. I ran xinfo, looked in the file and saw that it was somehow picking up the license from the original direcoty I saved it to. Even though a copy was placed in a different location when I ran the license manager to install it. Once I renamed that copy, everything was cleaned up in the license manager. Thanks. |
你好,
很高兴知道这个问题得到了解决。 您可以从许可证管理器本身查看lic文件位置。 只是想分享.. -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Hello, Glad to know the issue got reolved. You can see the lic file location from license manager itself. just wanted to share.. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2597 浏览 7 评论
2921 浏览 4 评论
2375 浏览 9 评论
3475 浏览 0 评论
2554 浏览 15 评论
3090浏览 1评论
719浏览 1评论
597浏览 1评论
GMT+8, 2025-4-18 04:01 , Processed in 1.712188 second(s), Total 90, Slave 74 queries .
