扫一扫,分享给好友
嗨专家
我刚刚将xilinx 14.2安装到我的窗口xp 32位,安装完成没有任何问题,但我的linceses文件没有附加,因为MANAGE XILINX许可证没有启动。 我该如何解决这个问题? 问候 Muneeb 以上来自于谷歌翻译 以下为原文 Hi experts i have just insatlled xilinx 14.2 to my window xp 32 bit, installation is completed without any problem but my linceses file is not attaching because the MANAGE XILINX LICENSES is not launching. HOW SHOULD I FIX THIS PROBLEM? Regards Muneeb |
3个回答
谷歌
管理xilinx许可证 并按照前两个链接。 http://www.google.com/url?sa=t&rct=j&q=manage%20xilinx%20licenses&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=http%3A% 2F%2Fwww.xilinx.com%2Ftools%2Ffaq.htm&安培; EI = 57msUZfLI8jpigKV64HQBA&安培; USG = AFQjCNEmG3pUD5LTwja5Mz9JdwU2HakL1Q&安培; BVM = bv.47244034,d.cGE http://www.google.com/url?sa=t&rct=j&q=manage%20xilinx%20licenses&source=web&cd=2&cad=rja&ved=0CDMQFjAB&url=http%3A% 2F%2Fwww.xilinx.com%2Fsupport%2Flicensing_solution_center.htm&安培; EI = 57msUZfLI8jpigKV64HQBA&安培; USG = AFQjCNG6oyXEMgFpDOVoIzmq-sHsHz1mzg&安培; BVM = BV .... Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 manage xilinx licenses And follow the first two links. http://www.google.com/url?sa=t&rct=j&q=manage%20xilinx%20licenses&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.xilinx.com%2Ftools%2Ffaq.htm&ei=57msUZfLI8jpigKV64HQBA&usg=AFQjCNEmG3pUD5LTwja5Mz9JdwU2HakL1Q&bvm=bv.47244034,d.cGE http://www.google.com/url?sa=t&rct=j&q=manage%20xilinx%20licenses&source=web&cd=2&cad=rja&ved=0CDMQFjAB&url=http%3A%2F%2Fwww.xilinx.com%2Fsupport%2Flicensing_solution_center.htm&ei=57msUZfLI8jpigKV64HQBA&usg=AFQjCNG6oyXEMgFpDOVoIzmq-sHsHz1mzg&bvm=bv.... Austin Lesea Principal Engineer Xilinx San Jose |
嗨奥斯汀
我的软件中有许可证文件,但我的XLCM管理器无法正常工作,我应该如何启动它? 问候 Muneeb Ziaa 以上来自于谷歌翻译 以下为原文 Hi austin I have a licenses file in my software but my XLCM manager is not working, how should I launch it? Regards Muneeb Ziaa |
嗨,问题可能是由于XLCM尚未包含在操作系统PATH variuable中。
XLCM位于$ XILINX /../../ common / bin / nt目录中。 尝试将$ XILINX /../ common / bin / nt添加到PATH变量。谢谢。 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, the issue may be due to XLCM has not been included in the operating system PATH variuable. XLCM is located in $XILINX/../../common/bin/nt directory. Try adding $XILINX/../common/bin/nt to the PATH variable. Thanks.-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1384浏览 1评论
596浏览 1评论
461浏览 1评论
2014浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 16:07 , Processed in 1.343321 second(s), Total 79, Slave 63 queries .
