我想知道我们可以将Intel ATOM E3826的两个DDI端口同时配置为显示端口吗?
或两个端口为DP? 如上所述,数据表可以同时配置为eDP。 这是否也适用于HDMI和DP? 以上来自于谷歌翻译 以下为原文 I'm want to know that can we configure both DDI ports of Intel ATOM E3826 as Display port simultaneously? or both ports as DP? As mentioned datasheet both can be configured as eDP at same time. Does this applies to HDMI and DP also? |
您好Lalit_LogicFruit,感谢您发布您的询问。我已向您发送私信;
请看看你的inboxRegards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Lalit_LogicFruit, Thank you for posting your inquiry. I have sent you a private message; please take a look at your inbox Regards, Diego S. |
GMT+8, 2025-4-7 13:38 , Processed in 0.445259 second(s), Total 39, Slave 34 queries .
