嗨,
我试图在FIFO /流模式下配置LIS3DH并且有一些问题,因为数据表不是很清楚。 1)我可以将INT2配置为WaterMark中断吗?我没有看到任何选项将INT2配置为寄存器位中的中断,尽管规范似乎暗示它是可能的。我们的硬件将INT2引脚连接到GPIO,因此想知道将INT2配置为水印中断是一种选择。 2)由于我无法配置INT2,因此我继续轮询FIFO_SRC_REG的WTM位以查看是否已达到水印阈值电平(假设WTM位是要查找的位置)。但是,每当我读取FIFO_SRC_REG时,它就会变为0.我在CTRL_REG5(第6位)中启用了FIFO,并将模式设置在FIFO_CTRL_REG中。我错过了什么?此外,FIFO_SRC_REG对reg位的含义没有任何解释。 以上来自于谷歌翻译 以下为原文 Hi, I am trying to configure LIS3DH in FIFO/Stream mode and have a few questions as the data sheet is not very clear. 1) Can I configure the INT2 as the WaterMark interrupt? I don't see any option to configure INT2 as the interrupt in the register bits, although the spec seems to imply it is possible. Our hardware has the INT2 pin connected to a GPIO, hence would like to know if configuring INT2 as the watermark interrupt is an option. 2) Since I couldn't configure INT2, I went with polling the WTM bit of FIFO_SRC_REG to see if the watermark threshold level has reached (assuming WTM bit is the place to look for). However, whenever I read FIFO_SRC_REG it comes out as 0. I have enabled the FIFO in CTRL_REG5 (bit 6) and set the mode in FIFO_CTRL_REG. What am I missing? Also, FIFO_SRC_REG doesn't have any explanation on what the reg bits mean. |
第2点快速修正。
但是,每当我读取FIFO_SRC_REG时,它就会显示为0x20(如前所述,不是0)。 FIFO似乎是空的。 以上来自于谷歌翻译 以下为原文 Quick correction on point 2. However, whenever I read FIFO_SRC_REG it comes out as 0x20 (not 0 as mentioned before). FIFO seems to be empty. |
2882 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 23:35 , Processed in 1.287261 second(s), Total 75, Slave 59 queries .
