嗨,来自Cadence方面,我迷失了如何定制引脚名称。
在节奏中,您只需放置引脚并根据需要命名它们,然后使用“创建单元视图 - 从单元格视图”,然后生成具有相同引脚命名的符号。 在ADS中,似乎你只能使用序号,这是真的吗? 另外,在节奏中,您只需检查并保存以查找连接问题。 似乎在ADS中,“检查设计”报告只是错过了很多未连接的引脚(似乎只能确保匹配的引脚数)。 以上来自于谷歌翻译 以下为原文 Hi, Coming from Cadence side, I am lost on how to get pin name customized. In cadence, you just place pins and name them whatever you want, and then use "create a cellview --from cellview" then a symbol is generated with same pin namings. In ADS, seems you can only use sequential numbers, is this true? also, in cadence, you just check and save to find connectivity problems. Seems in ADS, the "check design" report simply miss a lot of unconnected pins (it seems only make sure number of pins to match). |
1300 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1152浏览 1评论
762浏览 0评论
960浏览 0评论
1301浏览 0评论
GMT+8, 2024-12-31 05:48 , Processed in 1.072424 second(s), Total 45, Slave 39 queries .
