嗨专家,我正在尝试模拟一个微型电路组件(MSWT-4-20 +),它在Genesys上已经没有内置模型。
它是一个8引脚的部分,但只有4个端口是RF端口,它们具有相关的S参数数据。 我从Linear工具栏创建了一个8端口设备。 我将供应商网站上提供的4端口s参数文件加载到零件模型中。 我的问题是Genesys如何知道哪些端口是RF端口,因为芯片的引脚数(8)与s参数端口数(4)不匹配。 如果这不是我想要完成的事情的方式,我该怎么办? 以上来自于谷歌翻译 以下为原文 Hi Experts, I am trying to simulate a mini-circuit component (MSWT-4-20+) which does not have a built in model already on Genesys. It's an 8 pin part however only 4 of the ports are RF ports which has S-parameter data associated. I created a 8 port device from the Linear tool bar. And I loaded the 4 port s-parameter file provided on the vendor website into the part model. My question is how does Genesys know which ports are the RF ports because the number of pins(8) of the chip does not match with the number of s-parameter ports(4). If this is not the way to do what I want to accomplish, what should I do otherwise? |
嗨Donna,如果你正在进行线性模拟,你可以忽略控制引脚 - 你只需要考虑4端口的参数。
我已将此放入工作表中,以便向您展示如何使用制造商的S参数文件。 您需要将端口号与数据表匹配,以确保其余电路连接到正确的端口。 关心Dan Image:http://www.home.agilent.com/upload/cmc_upload/ck/4W/images/ace100x100.jpg! 以上来自于谷歌翻译 以下为原文 Hi Donna, If you are performing a linear simulation you can ignore the control pins - you only need to consider the 4 port s parameters. I have put this into a worksheet for you to show you how to use manufactures S parameters files. You will need to match the port numbers with the data sheet to make sure the rest of you circuit is connected to the correct port. Regards Dan Image: !http://www.home.agilent.com/upload/cmc_upload/ck/4W/images/ace100x100.jpg! 附件
1396 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2113 浏览 5 评论
3028 浏览 3 评论
1493浏览 1评论
840浏览 0评论
1257浏览 0评论
1397浏览 0评论
GMT+8, 2025-3-6 18:13 , Processed in 1.377294 second(s), Total 44, Slave 39 queries .
