你好,
我们希望使用一些PROC模块,但数量很少,WHITED必须为每个设备编程MAC地址(如果可能的话,从IEEE中购买一套)。 从一个EEPROM芯片读取一个48位EUI的MAC地址,设置第一次运行是一个很好的方法吗?(用CyByLyStEvice AddiScript()) 或者我们可以只使用一个随机静态地址(在第一次运行时产生的/可以改变,如果用户通过按下一个按钮为例),我不确定这一个,因为似乎没有人使用它… 我担心一些与手机兼容的问题。 谢谢你的回答。 以上来自于百度翻译 以下为原文 Hello, We want use some ProC module but in few quantity, and whitout having to programm MAC adress for each device (and whitout buying a set from IEEE if possible). Reading a MAC address from an EEPROM chip with 48 bits embeeded EUI, and set it the first run is a good way to do it ? ( with CyBle_SetDeviceAddress()) Or can we just use a random static address ( generated at the first run / can be changed if the user want it by pressing a button for exemple), i am not sure for this one ,because nobody seems to use it... Im afraid of some compatibility problem with phones for exemple . Thanks in advance for your answers. |
3个回答
每个CyPress PSoC或PROC芯片都有一个内部唯一ID,可以用CyGutUnQuid()API检索。请参阅“创建者帮助菜单系统参考指南”
鲍勃 以上来自于百度翻译 以下为原文 Each Cypress PSoC or PRoC chip has got an internal unique ID which you can retrieve with CyGetUniqueID() API. See "System Reference Guides from Creator help menu) Bob |
ncmza 发表于 2018-11-27 06:47 哦,它是为了我们想要销售的产品,所以蓝牙设备地址必须是唯一的(至少是24位组织唯一标识符),并且从IEEE购买。如果我理解正确的话。 以上来自于百度翻译 以下为原文 Oh, it's for products that we want to sell , so the bluetooth device address have to be unique (at least the 24 bits Organization Unique Identifier) and purchased from IEEE. If i understand correctly. |
mmuwyrwe 发表于 2018-11-27 07:02 这是一个更好的问题,要求一个直接的柏树员工,以确保遵守规则。 尽管如此,我相信他们至少提到你至少可以自由地使用他们的ID号/值来进行开发。 蓝牙地址可以使用CyPress OUI和“硅生成”公司分配的“设备地址的一部分”。 以上来自于百度翻译 以下为原文 This is a question better asked to a direct cypress employee to ensure following the rules. Still, I believe they mention that you are at least free to use their ID numbers/values for development purposes at the very least. The bluetooth address can use the Cypress OUI with the "Silicon generated 'Company Assigned' part of device address". |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 19:12 , Processed in 0.940946 second(s), Total 81, Slave 65 queries .
