我不能在运行Win7 64bit的2台不同PC上运行PlanAhead 14.4。
将出现一个命令窗口,其中包含TCL提示和消息: 特定于应用程序的初始化失败:无法重命名“auto_load”:命令不存在 % 如果我尝试start_gui,我会得到以下内容。 %start_gui 错误:[通用17-211]加载jvm时出错。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 I cannot run PlanAhead 14.4 on 2 different PC's running Win7 64bit. A command window appears with TCL prompt and the message: application-specific initialization failed: can't rename "auto_load": command doesn't exist % If I try start_gui I get the following. % start_gui ERROR: [Common 17-211] Error loading jvm. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
9个回答
我通过下载4个独立的部分(而不仅仅是windows单片tar)进行了全新安装,检查md5然后安装。
PlanAhead现在正常运作。 那(我认为)意味着只下载的窗口已损坏。 下载后建议其他人进行全新安装,确保在安装前检查md5哈希值。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I did a clean install by downloading the 4 separate pieces (rather the the windows only monolithic tar), checking the md5 for each then installing. PlanAhead now functions. That (I think) implies that the windows only download was corrupted. Advice to others, for clean install, after downloading ensure one checks the md5 hash before installing. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P ChuView solution in original post |
嗨
首先检查java版本。使用ISE Design Suite 14.1版本,xilinx工具使用Java 1.7.0。 以上来自于谷歌翻译 以下为原文 hi first check the java version.With the ISE Design Suite 14.1 release,xilinx tool use Java 1.7.0. |
谢谢回复。
PlanAhead在它的包树下安装它自己的JRE 7.0.x. 我还安装了JDK 7.0.10(以及相关的JRE)。 所以我认为这不是问题所在。 根本原因似乎是TCL auto_load和它缺失的事实。 不幸的是我不太了解TCL来调试它。 似乎可能缺少一个TCL包。 我想我可以尝试使用Windows 7的vanilla安装,但这样做太多了。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 Thanks for the reply. PlanAhead installs it's own JRE 7.0.x underneath it's package tree. I have JDK 7.0.10 (as well as the associated JRE) also installed. So I don't think this is the issue. The underlying cause seems to be with the TCL auto_load and the fact that it is missing. Unfortunately I don't know enough about TCL to debug it. Seems there maybe a TCL package that is missing. I suppose I could try again with a vanilla install of Windows 7 but that is too much work. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
PlanAhead现在正常运作。 那(我认为)意味着只下载的窗口已损坏。 下载后建议其他人进行全新安装,确保在安装前检查md5哈希值。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 I did a clean install by downloading the 4 separate pieces (rather the the windows only monolithic tar), checking the md5 for each then installing. PlanAhead now functions. That (I think) implies that the windows only download was corrupted. Advice to others, for clean install, after downloading ensure one checks the md5 hash before installing. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
我在Windows和Linux上遇到同样的问题,
以上来自于谷歌翻译 以下为原文 I have the same problem on both windows and Linux, |
None
以上来自于谷歌翻译 以下为原文 Here is the error Log: # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007f9d3681355, pid=3616, tid=4972 # # JRE version: 7.0_07-b11 # Java VM: Java HotSpot(TM) 64-Bit Server VM (23.3-b01 mixed mode windows-amd64 compressed oops) # Problematic frame: # C [msvcrt.dll+0x1355] free_dbg+0x5 # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x0000000033ee5000): JavaThread "Swing-Shell" daemon [_thread_in_native, id=4972, stack(0x0000000034a00000,0x0000000034d00000)] siginfo: ExceptionCode=0xc0000005, reading address 0x00000000000000c5 Registers: RAX=0x00000000000000c5, RBX=0x000007f9d3a78610, RCX=0x000000003027417c, RDX=0x000007f9a3808c54 RSP=0x0000000034cfc468, RBP=0x0000000034cfc570, RSI=0x0000000080040111, RDI=0x0000000000000000 R8 =0x0000000000000010, R9 =0x0000000000000000, R10=0x000000003027417c, R11=0x000007f9d59f15f8 R12=0x000007f9d3a78600, R13=0x0000000034cfca38, R14=0x000000003027417c, R15=0x0000000000000000 RIP=0x000007f9d3681355, EFLAGS=0x0000000000010293 Top of Stack: (sp=0x0000000034cfc468) 0x0000000034cfc468: 000007f9d38723d6 0000000000000002 0x0000000034cfc478: 0000000034cfc5c8 0000000000000b00 0x0000000034cfc488: 0000000034cfc5c8 000000000000004e 0x0000000034cfc498: 0000000034cfc630 0000000100000000 0x0000000034cfc4a8: 000007f9d3a7f328 0000000000000401 0x0000000034cfc4b8: 0000000000000000 0000000000000000 0x0000000034cfc4c8: 0000000034cfc550 004600460044007b 0x0000000034cfc4d8: 0043004400430041 00370036002d0035 0x0000000034cfc4e8: 0034002d00460039 002d003600350031 0x0000000034cfc4f8: 0037003400390038 004300350043002d 0x0000000034cfc508: 0043004200360037 0037003600420030 0x0000000034cfc518: 00000000007d0046 0000000032270000 0x0000000034cfc528: 0000000034cfc630 0000000000000000 0x0000000034cfc538: 000007f9d3a84680 0000000000000027 0x0000000034cfc548: 000007f9d3884fd8 0000000000000001 0x0000000034cfc558: 0000000000008000 fffffffffffffffe Instructions: (pc=0x000007f9d3681355) 0x000007f9d3681335: 3a 04 0a 75 1b 48 ff c1 49 ff c8 f6 c1 07 75 ee 0x000007f9d3681345: eb 87 cc 90 90 90 90 90 90 90 90 48 b8 60 81 91 0x000007f9d3681355: 0a 00 00 00 00 ff e0 90 90 90 90 90 90 90 90 48 0x000007f9d3681365: b8 60 73 91 0a 00 00 00 00 ff e0 83 ec 20 48 83 Register to memory mapping: RAX=0x00000000000000c5 is an unknown value RBX=0x000007f9d3a78610 is an unknown value RCX=0x000000003027417c is an unknown value RDX=0x000007f9a3808c54 is an unknown value RSP=0x0000000034cfc468 is pointing into the stack for thread: 0x0000000033ee5000 RBP=0x0000000034cfc570 is pointing into the stack for thread: 0x0000000033ee5000 RSI=0x0000000080040111 is an unknown value RDI=0x0000000000000000 is an unknown value R8 =0x0000000000000010 is an unknown value R9 =0x0000000000000000 is an unknown value R10=0x000000003027417c is an unknown value R11=0x000007f9d59f15f8 is an unknown value R12=0x000007f9d3a78600 is an unknown value R13=0x0000000034cfca38 is pointing into the stack for thread: 0x0000000033ee5000 R14=0x000000003027417c is an unknown value R15=0x0000000000000000 is an unknown value Stack: [0x0000000034a00000,0x0000000034d00000], sp=0x0000000034cfc468, free space=3057k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [msvcrt.dll+0x1355] free_dbg+0x5 Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j sun.awt.shell.Win32ShellFolder2.getDisplayNameOf(JJI)Ljava/lang/String;+0 j sun.awt.shell.Win32ShellFolder2.getFileSystemPath(JJ)Ljava/lang/String;+66 j sun.awt.shell.Win32ShellFolder2.access$400(JJ)Ljava/lang/String;+2 j sun.awt.shell.Win32ShellFolder2$10.call()Lsun/awt/shell/Win32ShellFolder2;+50 j sun.awt.shell.Win32ShellFolder2$10.call()Ljava/lang/Object;+1 j java.util.concurrent.FutureTask$Sync.innerRun()V+29 j java.util.concurrent.FutureTask.run()V+4 j java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V+46 j java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5 j sun.awt.shell.Win32ShellFolderManager2$ComInvoker$3.run()V+7 j java.lang.Thread.run()V+11 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) =>0x0000000033ee5000 JavaThread "Swing-Shell" daemon [_thread_in_native, id=4972, stack(0x0000000034a00000,0x0000000034d00000)] 0x000000002bf89000 JavaThread "HFileChooser Load File/Folder Choosers Thread" [_thread_blocked, id=412, stack(0x0000000034700000,0x0000000034a00000)] 0x000000002bd3a000 JavaThread "Monitor File Timestamp" [_thread_blocked, id=392, stack(0x0000000034400000,0x0000000034700000)] 0x000000002d45d800 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=3668, stack(0x0000000031e60000,0x0000000032160000)] 0x000000002bed5000 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3560, stack(0x000000002d100000,0x000000002d400000)] 0x000000002c7e7800 JavaThread "AWT-EventQueue-1" [_thread_in_vm, id=2472, stack(0x000000002cc00000,0x000000002cf00000)] 0x000000001a317800 JavaThread "Process Messages" [_thread_blocked, id=1772, stack(0x000000002c800000,0x000000002cb00000)] 0x000000001a2fd800 JavaThread "Thread-3" [_thread_blocked, id=3120, stack(0x0000000003c90000,0x0000000005090000)] 0x000000002c0f7800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=2524, stack(0x000000002c100000,0x000000002c400000)] 0x000000002949c800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3420, stack(0x0000000029ea0000,0x000000002a1a0000)] 0x000000002949d800 JavaThread "AWT-Shutdown" [_thread_blocked, id=4924, stack(0x0000000029ba0000,0x0000000029ea0000)] 0x0000000029451000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4388, stack(0x00000000298a0000,0x0000000029ba0000)] 0x000000002940b800 JavaThread "TimerQueue" daemon [_thread_blocked, id=4740, stack(0x00000000295a0000,0x00000000298a0000)] 0x0000000020fc0800 JavaThread "Service Thread" daemon [_thread_blocked, id=4320, stack(0x0000000027c30000,0x0000000027f30000)] 0x0000000020fb0800 JavaThread "C1 CompilerThread3" daemon [_thread_blocked, id=2988, stack(0x0000000027b30000,0x0000000027c30000)] 0x0000000020fa0800 JavaThread "C2 CompilerThread2" daemon [_thread_blocked, id=1492, stack(0x0000000027a30000,0x0000000027b30000)] 0x0000000020f90800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=4888, stack(0x0000000027930000,0x0000000027a30000)] 0x0000000020f80800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=4224, stack(0x0000000027830000,0x0000000027930000)] 0x00000000267a0800 JavaThread "Attach Listener" daemon [_thread_blocked, id=3220, stack(0x0000000027530000,0x0000000027830000)] 0x0000000026790800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3136, stack(0x0000000027230000,0x0000000027530000)] 0x0000000026792800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=1808, stack(0x0000000026f30000,0x0000000027230000)] 0x00000000218c3800 JavaThread "Finalizer" daemon [_thread_blocked, id=5052, stack(0x0000000026c30000,0x0000000026f30000)] 0x00000000218b1800 JavaThread "Reference Handler" daemon [_thread_blocked, id=4564, stack(0x0000000026930000,0x0000000026c30000)] 0x000000001a34b800 JavaThread "main" [_thread_blocked, id=3340, stack(0x000000001a450000,0x000000001a550000)] Other Threads: 0x0000000021862000 VMThread [stack: 0x0000000026830000,0x0000000026930000] [id=3068] 0x0000000021830800 WatcherThread [stack: 0x0000000027f30000,0x0000000028030000] [id=4872] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap par new generation total 55296K, used 18760K [0x0000000778000000, 0x000000077bc00000, 0x000000077bc00000) eden space 49152K, 25% used [0x0000000778000000, 0x0000000778c52300, 0x000000077b000000) from space 6144K, 100% used [0x000000077b000000, 0x000000077b600000, 0x000000077b600000) to space 6144K, 0% used [0x000000077b600000, 0x000000077b600000, 0x000000077bc00000) concurrent mark-sweep generation total 69632K, used 11271K [0x000000077bc00000, 0x0000000780000000, 0x00000007f8000000) concurrent-mark-sweep perm gen total 131072K, used 26404K [0x00000007f8000000, 0x0000000800000000, 0x0000000800000000) Card table byte_map: [0x0000000020ff0000,0x0000000021440000] byte_map_base: 0x000000001d430000 Polling page: 0x000000001a550000 Code Cache [0x000000001a570000, 0x000000001ab40000, 0x0000000020570000) total_blobs=2148 nmethods=1557 adapters=508 free_code_cache=92470Kb largest_free_block=94598016 Compilation events (10 events): Event: 6.122 Thread 0x0000000020fb0800 1815 3 sun.awt.image.IntegerInterleavedRaster::setDataElements (94 bytes) Event: 6.122 Thread 0x0000000020fb0800 nmethod 1815 0x000000001a6b0090 code [0x000000001a6b0240, 0x000000001a6b08e8] Event: 6.123 Thread 0x0000000020fa0800 1817 4 javax.swing.UIDefaults::get (21 bytes) Event: 6.132 Thread 0x0000000020fa0800 nmethod 1817 0x000000001a962010 code [0x000000001a962180, 0x000000001a9627f8] Event: 6.138 Thread 0x0000000020fb0800 1818 3 java.lang.Integer::stringSize (21 bytes) Event: 6.138 Thread 0x0000000020fb0800 nmethod 1818 0x000000001a85ea50 code [0x000000001a85ebc0, 0x000000001a85edf0] Event: 6.139 Thread 0x0000000020fb0800 1819 3 java.lang.Integer::getChars (131 bytes) Event: 6.139 Thread 0x0000000020fb0800 nmethod 1819 0x000000001a841910 code [0x000000001a841ac0, 0x000000001a841f70] Event: 6.156 Thread 0x0000000020fb0800 1820 3 java.io.File:: Event: 6.157 Thread 0x0000000020fb0800 nmethod 1820 0x000000001a6c8f90 code [0x000000001a6c9120, 0x000000001a6c95a8] GC Heap History (4 events): Event: 2.432 GC heap before {Heap before GC invocations=0 (full 0): par new generation total 55296K, used 49152K [0x0000000778000000, 0x000000077bc00000, 0x000000077bc00000) eden space 49152K, 100% used [0x0000000778000000, 0x000000077b000000, 0x000000077b000000) from space 6144K, 0% used [0x000000077b000000, 0x000000077b000000, 0x000000077b600000) to space 6144K, 0% used [0x000000077b600000, 0x000000077b600000, 0x000000077bc00000) concurrent mark-sweep generation total 69632K, used 0K [0x000000077bc00000, 0x0000000780000000, 0x00000007f8000000) concurrent-mark-sweep perm gen total 131072K, used 14226K [0x00000007f8000000, 0x0000000800000000, 0x0000000800000000) Event: 2.453 GC heap after Heap after GC invocations=1 (full 0): par new generation total 55296K, used 6143K [0x0000000778000000, 0x000000077bc00000, 0x000000077bc00000) eden space 49152K, 0% used [0x0000000778000000, 0x0000000778000000, 0x000000077b000000) from space 6144K, 99% used [0x000000077b600000, 0x000000077bbffff8, 0x000000077bc00000) to space 6144K, 0% used [0x000000077b000000, 0x000000077b000000, 0x000000077b600000) concurrent mark-sweep generation total 69632K, used 1323K [0x000000077bc00000, 0x0000000780000000, 0x00000007f8000000) concurrent-mark-sweep perm gen total 131072K, used 14226K [0x00000007f8000000, 0x0000000800000000, 0x0000000800000000) } Event: 5.382 GC heap before {Heap before GC invocations=1 (full 0): par new generation total 55296K, used 55295K [0x0000000778000000, 0x000000077bc00000, 0x000000077bc00000) eden space 49152K, 100% used [0x0000000778000000, 0x000000077b000000, 0x000000077b000000) from space 6144K, 99% used [0x000000077b600000, 0x000000077bbffff8, 0x000000077bc00000) to space 6144K, 0% used [0x000000077b000000, 0x000000077b000000, 0x000000077b600000) concurrent mark-sweep generation total 69632K, used 1323K [0x000000077bc00000, 0x0000000780000000, 0x00000007f8000000) concurrent-mark-sweep perm gen total 131072K, used 22873K [0x00000007f8000000, 0x0000000800000000, 0x0000000800000000) Event: 5.466 GC heap after Heap after GC invocations=2 (full 0): par new generation total 55296K, used 6144K [0x0000000778000000, 0x000000077bc00000, 0x000000077bc00000) eden space 49152K, 0% used [0x0000000778000000, 0x0000000778000000, 0x000000077b000000) from space 6144K, 100% used [0x000000077b000000, 0x000000077b600000, 0x000000077b600000) to space 6144K, 0% used [0x000000077b600000, 0x000000077b600000, 0x000000077bc00000) concurrent mark-sweep generation total 69632K, used 11271K [0x000000077bc00000, 0x0000000780000000, 0x00000007f8000000) concurrent-mark-sweep perm gen total 131072K, used 22873K [0x00000007f8000000, 0x0000000800000000, 0x0000000800000000) } Deoptimization events (10 events): Event: 5.852 Thread 0x000000002c7e7800 Uncommon trap -83 fr.pc 0x000000001aad3bc0 Event: 5.875 Thread 0x000000002c7e7800 Uncommon trap -34 fr.pc 0x000000001a766ba4 Event: 5.902 Thread 0x000000002c7e7800 Uncommon trap -34 fr.pc 0x000000001ab11180 Event: 6.077 Thread 0x000000002bf89000 Uncommon trap -83 fr.pc 0x000000001aab147c Event: 6.084 Thread 0x000000002bf89000 Uncommon trap -58 fr.pc 0x000000001a992f28 Event: 6.090 Thread 0x000000002bf89000 Uncommon trap -58 fr.pc 0x000000001a992f28 Event: 6.091 Thread 0x000000002bf89000 Uncommon trap -58 fr.pc 0x000000001a992f28 Event: 6.092 Thread 0x000000002bf89000 Uncommon trap -58 fr.pc 0x000000001a992f28 Event: 6.094 Thread 0x000000002bf89000 Uncommon trap -58 fr.pc 0x000000001a97ac94 Event: 6.135 Thread 0x000000002bf89000 Uncommon trap 668 fr.pc 0x000000001aa5ff6c Internal exceptions (10 events): Event: 5.983 Thread 0x000000002c7e7800 Threw 0x0000000778899f98 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 5.986 Thread 0x000000002c7e7800 Threw 0x00000007788a5b70 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 5.987 Thread 0x000000002c7e7800 Threw 0x00000007788aa240 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 5.989 Thread 0x000000002c7e7800 Threw 0x00000007788bf6d0 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 5.991 Thread 0x000000002c7e7800 Threw 0x00000007788c69a8 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 5.994 Thread 0x000000002c7e7800 Threw 0x00000007788d3308 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 6.070 Thread 0x000000002bf89000 Threw 0x0000000778912308 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 6.073 Thread 0x000000002bf89000 Threw 0x0000000778915780 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 6.083 Thread 0x000000002bf89000 Threw 0x0000000778a24210 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Event: 6.083 Thread 0x000000002bf89000 Threw 0x0000000778a269a0 at C:jdk7u1_64pjdk7u7hotspotsrcsharevmprimsjvm.cpp:1166 Events (10 events): Event: 6.151 loading class 0x0000000028042f60 Event: 6.151 loading class 0x0000000028042f60 done Event: 6.153 loading class 0x00000000280430b0 Event: 6.153 loading class 0x00000000280430b0 done Event: 6.155 loading class 0x0000000028043110 Event: 6.155 loading class 0x0000000028043110 done Event: 6.159 loading class 0x0000000028042f00 Event: 6.159 loading class 0x0000000028042f00 done Event: 6.160 loading class 0x00000000280431d0 Event: 6.160 loading class 0x00000000280431d0 done Dynamic libraries: 0x0000000140000000 - 0x000000014000e000 C:Xilinx14.4ISE_DSPlanAheadbinunwrappedwin64.oplanAhead.exe 0x000007f9d5da0000 - 0x000007f9d5f5e000 C:WindowsSYSTEM32ntdll.dll 0x000007f9d3730000 - 0x000007f9d3866000 C:Windowssystem32KERNEL32.DLL 0x000007f9d2e00000 - 0x000007f9d2ef3000 C:Windowssystem32KERNELBASE.dll 0x000000000a900000 - 0x000000000a945000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.oSHSMP64.dll 0x0000000180000000 - 0x0000000180013000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_signals.dll 0x0000000000420000 - 0x0000000000ca1000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_common.dll 0x00000000001f0000 - 0x0000000000206000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_commonmain.dll 0x0000000000210000 - 0x00000000002fe000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.ostlport.5.2.dll 0x000000005c7a0000 - 0x000000005c843000 C:WindowsWinSxSamd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6871_none_08e717a5a83adddfMSVCR90.dll 0x000007f9d3210000 - 0x000007f9d335c000 C:Windowssystem32USER32.dll 0x000007f9d3530000 - 0x000007f9d360e000 C:Windowssystem32ADVAPI32.dll 0x000007f9d0800000 - 0x000007f9d0809000 C:WindowsSYSTEM32VERSION.dll 0x0000000000d20000 - 0x0000000001009000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibCOIN-all.dll 0x0000000001010000 - 0x00000000011c5000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibSecurity.dll 0x0000000000310000 - 0x000000000031f000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_date_time.dll 0x00000000011d0000 - 0x00000000011f7000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_filesystem.dll 0x0000000001200000 - 0x0000000001271000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_program_options.dll 0x0000000001280000 - 0x000000000132f000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_regex.dll 0x0000000001330000 - 0x0000000001339000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_system.dll 0x0000000001340000 - 0x0000000001356000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_thread.dll 0x0000000001360000 - 0x00000000013a3000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibcurl.dll 0x00000000013b0000 - 0x0000000001433000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibhdlpsolve.dll 0x0000000001440000 - 0x00000000014f7000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibhdxml.dll 0x0000000001500000 - 0x0000000001a430d3 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibisl_iostreams.dll 0x0000000001a50000 - 0x0000000001a79000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibisl_sysinfo.dll 0x000000005bf10000 - 0x000000005c62f000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinserverjvm.dll 0x0000000001a80000 - 0x0000000001a92000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.opthreadVC.dll 0x0000000001aa0000 - 0x0000000001ab6000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdiconfig.dll 0x0000000001ac0000 - 0x0000000001ade000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdizlib.dll 0x0000000010000000 - 0x000000001012a000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.otcl85t.dll 0x0000000012000000 - 0x0000000012282000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.oxerces-c_3_1.dll 0x000007f9d5a50000 - 0x000007f9d5a57000 C:Windowssystem32PSAPI.DLL 0x000007f9d4ca0000 - 0x000007f9d4ece000 C:Windowssystem32WININET.dll 0x000007f9ccfa0000 - 0x000007f9cd054000 C:WindowsSYSTEM32WINHTTP.dll 0x000007f9d5a60000 - 0x000007f9d5bb6000 C:Windowssystem32urlmon.dll 0x000007f9cf520000 - 0x000007f9cf529000 C:WindowsSYSTEM32WSOCK32.dll 0x000000005c6a0000 - 0x000000005c773000 C:WindowsWinSxSamd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6871_none_08e717a5a83adddfMSVCP90.dll 0x000007f9d3870000 - 0x000007f9d4b58000 C:Windowssystem32SHELL32.dll 0x000007f9d3360000 - 0x000007f9d34a0000 C:Windowssystem32GDI32.dll 0x000007f9d3680000 - 0x000007f9d3725000 C:Windowssystem32msvcrt.dll 0x000007f9d34a0000 - 0x000007f9d34e8000 C:WindowsSYSTEM32sechost.dll 0x000007f9d4b60000 - 0x000007f9d4ca0000 C:Windowssystem32RPCRT4.dll 0x000007f9d1690000 - 0x000007f9d16a5000 C:WindowsSYSTEM32NETAPI32.dll 0x000007f9d5540000 - 0x000007f9d55e1000 C:Windowssystem32COMDLG32.dll 0x000007f9d2f00000 - 0x000007f9d2fa4000 C:WindowsWinSxSamd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9200.16384_none_7762d5fd3178b04eCOMCTL32.dll 0x0000000001b80000 - 0x0000000001b8c000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_chrono.dll 0x000007f9d3620000 - 0x000007f9d3678000 C:Windowssystem32WS2_32.dll 0x000007f9d55f0000 - 0x000007f9d564e000 C:Windowssystem32WLDAP32.dll 0x0000000001bc0000 - 0x0000000001bd9000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_iostreams.dll 0x000007f9cee00000 - 0x000007f9cee20000 C:WindowsSYSTEM32WINMM.dll 0x000000005c950000 - 0x000000005ca22000 C:WindowsSYSTEM32MSVCR100.dll 0x000007f9d5650000 - 0x000007f9d5866000 C:Windowssystem32iertutil.dll 0x000007f9d5210000 - 0x000007f9d53c0000 C:WindowsSYSTEM32combase.dll 0x000007f9d53c0000 - 0x000007f9d553e000 C:Windowssystem32ole32.dll 0x000007f9d59e0000 - 0x000007f9d5a30000 C:Windowssystem32SHLWAPI.dll 0x000007f9d2790000 - 0x000007f9d279e000 C:WindowsSYSTEM32netutils.dll 0x000007f9d2890000 - 0x000007f9d28b4000 C:WindowsSYSTEM32srvcli.dll 0x000007f9d13b0000 - 0x000007f9d13c5000 C:WindowsSYSTEM32wkscli.dll 0x000007f9d5d90000 - 0x000007f9d5d99000 C:Windowssystem32NSI.dll 0x000007f9ce570000 - 0x000007f9ce5a2000 C:WindowsSYSTEM32WINMMBASE.dll 0x000007f9d0fe0000 - 0x000007f9d1076000 C:WindowsSYSTEM32SHCORE.DLL 0x000007f9d34f0000 - 0x000007f9d3529000 C:Windowssystem32IMM32.DLL 0x000007f9d4ed0000 - 0x000007f9d4fe5000 C:Windowssystem32MSCTF.dll 0x0000000005090000 - 0x0000000005383000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_commontasks.dll 0x0000000005c90000 - 0x00000000062cc000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_coretasks.dll 0x00000000062d0000 - 0x0000000006497000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_chipscope.dll 0x00000000064a0000 - 0x00000000074bd000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_constraints.dll 0x00000000074c0000 - 0x000000000878c000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_coregen.dll 0x000000000a950000 - 0x000000000df9f000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_designutils.dll 0x0000000008790000 - 0x0000000009366000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_device.dll 0x0000000009370000 - 0x0000000009684000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_drc.dll 0x0000000009690000 - 0x000000000991d000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_filemgmt.dll 0x0000000009920000 - 0x0000000009cf6000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_netlist.dll 0x000000000dfa0000 - 0x000000000f0c3000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_place.dll 0x0000000009d00000 - 0x000000000a222000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_power.dll 0x000000000a230000 - 0x000000000a5e2000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_project.dll 0x000000000f0d0000 - 0x000000000f66d000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_r***.dll 0x000000000f670000 - 0x000000000fa68000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_runs.dll 0x0000000010130000 - 0x0000000010c08000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_timing.dll 0x000000000a5f0000 - 0x000000000a65e000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.oliblmx6.0.dll 0x0000000001f60000 - 0x0000000001f68000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibpsta_dllwrapper.dll 0x0000000010c10000 - 0x00000000113df000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_coregenipxact.dll 0x00000000113e0000 - 0x0000000011b80000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibverific.dll 0x000000000a660000 - 0x000000000a6dd000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibboost_serialization.dll 0x000000000fa70000 - 0x000000000ffb4000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_xdm.dll 0x000000000a710000 - 0x000000000a7a0000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibise.dll 0x0000000012290000 - 0x000000001286c000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_abc_nomp.dll 0x000000000a7a0000 - 0x000000000a8c8000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_dlyest.dll 0x000000000a8d0000 - 0x000000000a8ea000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_hmetis.dll 0x000000005c780000 - 0x000000005c791000 C:WindowsWinSxSamd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9VCOMP90.DLL 0x0000000012870000 - 0x0000000012e5e000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_route.dll 0x0000000011b80000 - 0x0000000011daa000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_labtools.dll 0x0000000012e60000 - 0x000000001339b000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_memdata.dll 0x00000000133a0000 - 0x0000000014acf000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_synth.dll 0x0000000014ad0000 - 0x0000000014f0e000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_ip.dll 0x0000000011e70000 - 0x0000000011ead000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_simbridge_kernel.dll 0x0000000014f10000 - 0x0000000015386000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_wavedata.dll 0x0000000016690000 - 0x0000000018748000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_tcltasks.dll 0x0000000018760000 - 0x00000000189d4000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_bitstream.dll 0x00000000189e0000 - 0x0000000018ab4000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_dsp.dll 0x0000000018ac0000 - 0x0000000018b2e000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_edk.dll 0x0000000018b30000 - 0x0000000018d3e000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_simdata.dll 0x0000000019280000 - 0x00000000193d6000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_planaheadtasks.dll 0x00000000193f0000 - 0x000000001a238000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_ipservicestasks.dll 0x000000005bf00000 - 0x000000005bf0f000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinverify.dll 0x000000005bed0000 - 0x000000005bef8000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinjava.dll 0x000000005beb0000 - 0x000000005bec5000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinzip.dll 0x000000005be90000 - 0x000000005bea9000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinnet.dll 0x000007f9d2510000 - 0x000007f9d256c000 C:Windowssystem32mswsock.dll 0x000000005be70000 - 0x000000005be81000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinnio.dll 0x0000000028430000 - 0x0000000028716000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_fed.dll 0x0000000028730000 - 0x0000000028991000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_guitools.dll 0x00000000289b0000 - 0x00000000289b7000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_commonx11.dll 0x00000000289d0000 - 0x0000000028dbe000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_r***tasks.dll 0x0000000028ed0000 - 0x0000000029119000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_labtoolstasks.dll 0x0000000029130000 - 0x00000000292e8000 C:Xilinx14.4ISE_DSPlanAheadlibwin64.olibrdi_simtcltasks.dll 0x000000005bcd0000 - 0x000000005be63000 C:Xilinx14.4ISE_DSPlanAheadtpswin64jrebinawt.dll 0x000007f9d5910000 - 0x000007f9d59d3000 C:Windowssystem32OLEAUT32.dll 0x000007f9ccc20000 - 0x000007f9cccbf000 C:Windowssystem32apphelp.dll 0x000007f9d1b70000 - 0x000007f9d1c53000 C:Windowssystem32uxtheme.dll 0x000007f9d0df0000 - 0x000007f9d0e11000 C:WindowsSYSTEM32dwmapi.dll 0x000007f9d2b10000 - 0x000007f9d2b1a000 C:WindowsSYSTEM32CRYPTBASE.dll 0x000007f9d2ab0000 - 0x000007f9d2b0c000 C:WindowsSYSTEM32bcryptPrimitives.dll 0x000007f9d2680000 - 0x000007f9d269a000 C:WindowsSYSTEM32CRYPTSP.dll 0x000007f9d21f0000 - 0x000007f9d2239000 C:Windowssystem32rsaenh.dll 0x000007f9d2490000 - 0x000007f9d24af000 C:WindowsSYSTEM32USERENV.dll 0x000007f9d2cd0000 - 0x000007f9d2ce5000 C:WindowsSYSTEM32profapi.dll VM Arguments: jvm_args: -Dsun.java2d.pmoffscreen=false -Xverify:none -Dswing.aatext=true -XX:-UsePerfData -Djdk.map.althashing.threshold=512 -XX:PermSize=128m -XX:MaxPermSize=128m -XX:NewSize=60m -XX:MaxNewSize=60m -XX:+UseConcMarkSweepGC -XX:+UseParNewGC -XX:+CMSParallelRemarkEnabled -XX:+CMSScavengeBeforeRemark -XX:+UseNUMA -XX:+AggressiveOpts -XX:+UseFastAccessorMethods -XX:+UseFastEmptyMethods -XX:+UseBiasedLocking -XX:+TieredCompilation -Xms128m -Xmx2048m -Xss3m java_command: Launcher Type: generic Environment Variables: PATH=C:/Xilinx/14.4/ISE_DS/PlanAhead/bin;C:/Xilinx/14.4/ISE_DS/PlanAhead/lib/win64.o;C:/Xilinx/14.4/ISE_DS/PlanAhead/tps/win64/jre/bin/server;C:/Xilinx/14.4/ISE_DS/PlanAhead/tps/win64/jre/bin;C:/Xilinx/14.4/ISE_DS/EDK/bin/nt64;C:/Xilinx/14.4/ISE_DS/EDK/lib/nt64;C:/Xilinx/14.4/ISE_DS/ISE/bin/nt64;C:/Xilinx/14.4/ISE_DS/ISE/lib/nt64;C:/Xilinx/14.4/ISE_DS/common/bin/nt64;C:/Xilinx/14.4/ISE_DS/common/lib/nt64;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesMicrosoftWeb Platform Installer;C:Program Files (x86)Microsoft ASP.NETASP.NET Web Pagesv1.0;C:Program Files (x86)Windows Kits8.0Windows Performance Toolkit;C:Program FilesMicrosoft SQL Server110ToolsBinn;C:Program FilesPuTTY;C:MATLABR2013aruntimewin64;C:MATLABR2013abin USERNAME=bharath OS=Windows_NT PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 30 Stepping 5, GenuineIntel --------------- S Y S T E M --------------- OS: Windows 8 , 64 bit Build 9200 CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 30 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht, tsc, tscinvbit Memory: 4k page, physical 8376840k(5604516k free), swap 13095432k(9162044k free) vm_info: Java HotSpot(TM) 64-Bit Server VM (23.3-b01) for windows-amd64 JRE (1.7.0_07-b11), built on Sep 7 2012 01:19:25 by "java_re" with unknown MS VC++:1600 time: Wed Mar 13 16:33:44 2013 elapsed time: 6 seconds |
我在win7 x64上也遇到了这个错误。
嘿Xilinx:我能做些什么来完全重新安装才能从中恢复? 以上来自于谷歌翻译 以下为原文 I also get this error on win7 x64. Hey Xilinx: Is there something short of a full re-install I can do to recover from this? |
你解决了这个问题吗?
我也有完全一样的问题。 如果您已经有解决方案,请告诉我。 谢谢! 以上来自于谷歌翻译 以下为原文 Have you sovled the problem? I have exactly the same problem. Please let me know if you have a solution already. Thanks! |
我转向14.5和Windows 8.另一个人!
就planahead而言,使用32位版本似乎对我来说很好,但不适用于Vivado! 以上来自于谷歌翻译 以下为原文 I moved on to 14.5 and Windows 8. Another nuisance! Using the 32 bit version seem to work fine for me as far as planahead is concerned, but not for Vivado! |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2308浏览 1评论
649浏览 1评论
514浏览 1评论
2061浏览 0评论
790浏览 0评论
GMT+8, 2025-2-11 16:54 , Processed in 1.487213 second(s), Total 93, Slave 77 queries .
