扫一扫,分享给好友
我在两台64位Windows机器上安装了2013.1,并且两者都崩溃了。
Vivado 2013.1窗口在崩溃之前会短暂出现。 如果我从命令行运行,我会看到: ****** Vivado v2013.1(64位)****由xbuild构建248050 3月27日星期三17:24:41 MDT 2013 ** Copyright 1986-1999,2001-2013 Xilinx,Inc。All Rights 保留。 警告:[Vivado 15-19]警告:未找到“实施”许可证。 如果在实施过程中使用Vivado WebPACK或电路板套件常用的设备锁定许可证,则可以安全地忽略此消息。 信息:[设备21-36]从C:/Xilinx/Vivado/2013.1/data/parts/arch.xmlParsing RTL基元文件[C:/Xilinx/Vivado/2013.1/data/parts/xilinx/rtl]加载零件和站点信息 /prims/rtl_prims.xml]Finished解析RTL原语文件[C:/Xilinx/Vivado/2013.1/data/parts/xilinx/rtl/prims/rtl_prims.xml]信息:[Common 17-362]使用Tcl App repository from' C:/Xilinx/Vivado/2013.1/data/XilinxTclStore'.INFO:[Common 17-364]正在更新Tcl app持久性清单'C:/Users/jwilkes/AppData/Roaming/Xilinx/Vivado/tclapp/manifest.tcl'start_guiAbnormal 程序终止(EXCEPtiON_ACCESS_VIOLATION)请查看'C:/Users/jwilkes/hs_err_pid4692.log'了解详情 日志文件不添加任何内容: ##发生了意外错误(EXCEPTION_ACCESS_VIOLATION)#Stack:没有可用的堆栈跟踪,请改用hs_err_.dmp。 以上来自于谷歌翻译 以下为原文 I have installed 2013.1 on two 64-bit Windows machines, and it crashes on both. The Vivado 2013.1 window appears briefly before it crashes. If I run from the command line, I see this: ****** Vivado v2013.1 (64-bit) **** Build 248050 by xbuild on Wed Mar 27 17:24:41 MDT 2013 ** Copyright 1986-1999, 2001-2013 Xilinx, Inc. All Rights Reserved. WARNING: [Vivado 15-19] WARNING: No 'Implementation' license found. This message may be safely ignored if a Vivado WebPACK or device-locked license, common for board kits, will be used during implementation. INFO: [Device 21-36] Loading parts and site information from C:/Xilinx/Vivado/2013.1/data/parts/arch.xml Parsing RTL primitives file [C:/Xilinx/Vivado/2013.1/data/parts/xilinx/rtl/prims/rtl_prims.xml] Finished parsing RTL primitives file [C:/Xilinx/Vivado/2013.1/data/parts/xilinx/rtl/prims/rtl_prims.xml] INFO: [Common 17-362] Using Tcl App repository from 'C:/Xilinx/Vivado/2013.1/data/XilinxTclStore'. INFO: [Common 17-364] Updating Tcl app persistent manifest 'C:/Users/jwilkes/AppData/Roaming/Xilinx/Vivado/tclapp/manifest.tcl' start_gui Abnormal program termination (EXCEPTION_ACCESS_VIOLATION) Please check 'C:/Users/jwilkes/hs_err_pid4692.log' for details The log file doesn't add anything: # # An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION) # Stack: no stack trace available, please use hs_err_ |
4个回答
哪个版本的Windows?Windows 7 x64应用了最新更新。
以上来自于谷歌翻译 以下为原文 Which version of Windows? Windows 7 x64 with latest updates applied. |
检查下载中的MD5哈希值。
有时,下载损坏可能导致安装后随机崩溃。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 Check the MD5 hashes on the download. Sometimes a corrupted download can result in random crashes after an install. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
我做了2013.1多文件下载并验证了MD5哈希值;
都好。 我尝试了三台不同的Windows 7 x64机器,Vivado 2013.1在所有这些机器上都崩溃了。 我也尝试过仅使用Windows的下载,结果相同。 以上来自于谷歌翻译 以下为原文 I did the 2013.1 multi-file download and verified the MD5 hashes; all good. I've tried three different Windows 7 x64 machines, and Vivado 2013.1 crashes on all of them. I've also tried the Windows-only download with the same result. |
安装了哪个版本的Vivado 2013.1?
如果您安装了Web包版本,则会出现导致其在各个位置崩溃的问题。 建议安装系统版本并使用Web Pack许可证。 退房:AR#55438了解详情。 如果这不能解决,那么建议打开一个网络案例。 -------------------------------------------------- -------------------------------我喜欢这些书:Free Range VHDL(免费),http://www.freerangefactory .org / site / pmwiki.php / Main / BooksVHDL for Logic Synthesis,Andrew RushtonFPGA Prototyping by VHDL examples,Pong P Chu 以上来自于谷歌翻译 以下为原文 Which version of Vivado 2013.1 was installed? If you installed the web pack version then there are issues which will cause it to crash in various places. Suggest installing the system version and use the web pack license. Check out: AR#55438 for details. If this doesn't fix then suggest opening a web case. --------------------------------------------------------------------------------- I like these books: Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books VHDL for Logic Synthesis, Andrew Rushton FPGA Prototyping by VHDL Examples, Pong P Chu |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2627浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 03:04 , Processed in 1.462360 second(s), Total 83, Slave 67 queries .
