您好,我有联想Ideapad 330-17IKB 81M第8代Intel i5,8GB RAM,东芝mq01abd100 SATA存储。
我从Lenovo Driver Download网站安装了Intel Optane Memory的驱动程序。 我可以看到我的BIOS已正确更新,但是当我打开Intel Optane Memory GUI时,它显示一个错误,它找不到任何兼容的磁盘。 根据我的阅读,这台存储类型的PC应该支持Optane。 我已附上我的系统信息(来自英特尔SSU应用程序)。 有人可以看看,如果它真的不兼容,请告诉我吗? 谢谢! 系统Info.txt.zip 5.5 K. 以上来自于谷歌翻译 以下为原文 Hello, I have a Lenovo Ideapad 330-17IKB 81M 8th gen Intel i5, 8GB RAM, Toshiba mq01abd100 SATA Storage. I installed the driver for Intel Optane Memory from Lenovo Driver Download site. I can see that my BIOS has been updated properly, but when I open the Intel Optane Memory GUI, it shows an error that it cannot find any compatible disk. From what I read, Optane should be supported in this PC w/ this storage type. I have attached my System Information (From Intel SSU App). Can someone take a look and let me know if it's really not compatible? Thanks!
4个回答
您好tarekc972,感谢您在英特尔®Optane™内存社区发布您的问题。在检查了销售Optane ready board的推荐制造商后,联想不在此列表中。
这并不一定意味着Optane内存不能在您的主板上运行,这意味着英特尔尚未测试或验证其他供应商的主板。 以下是推荐供应商的列表:https://www.intel.com/content/www/us/en/support/articles/000024020/memory-and-storage/intel-optane-memory.html你在哪里做广告宣传你的 Optane准备好的笔记本电脑?为了让Optane工作,您需要确认BIOS已经准备就绪。 要确认BIO已准备好接受Optane,您可以检查是否能够将BIOS中的SATA模式从AHCI更改为“Intel RST premium and system acceleration”。 如果您的BIOS中没有该选项,这意味着主板不支持Optane,您需要联系您的制造商以确定他们是否有适用于您的笔记本电脑的Optane Ready BIOS。另外我想知道您是如何连接的 对系统的Optane记忆。 你正在使用什么界面?我将等待你的反馈。最好的问候,Juan N. 以上来自于谷歌翻译 以下为原文 Hello tarekc972, Thanks for posting your question in the Intel® Optane™ Memory community. After checking in the recommended manufactures that sell Optane ready boards, Lenovo is not in this list. This won’t necessarily mean that the Optane memory won’t work on your board, this means Intel has not tested or validated boards from other vendors. Here is the list of recommended vendors: https://www.intel.com/content/www/us/en/support/articles/000024020/memory-and-storage/intel-optane-memory.html Where were you advertised about your laptop being Optane ready? In order for the Optane to work you need to confirm the BIOS is ready for it. To confirm the BIOs is ready for Optane you can check if you are able to change the SATA mode in your BIOS from AHCI to “Intel RST premium and system acceleration”. If the option is not available in your BIOS this would mean the motherboard is not Optane ready and you will need to contact your manufacturer to be sure if they have an Optane Ready BIOS for your laptop. Additionally I would like to know how are you connecting the Optane memory to the system. What interface are you using? I will be waiting for your feedback. Best Regards, Juan N. |
jerry1978 发表于 2018-11-27 10:46 你好胡安, 非常感谢你的快速反应。 我的BIOS已从AHSI更新为“Intel RST premium和系统加速”。 是的,联想宣称这台笔记本电脑与Optane兼容。 我实际上从他们的官方网站上下载了Optane Driver。 我正在使用Intel Optane Memory界面。 笔记本电脑和上网本:: 300 series :: 330 17ikb type 81dm :: 81dm :: 81dm001uus :: pf12vj93 Lenovo PC支持 - 我们>>存储>> 该软件包提供英特尔快速存储威廉希尔官方网站 (IRST)驱动程序,支持330-15IKB(81DE型),330-17IKB(81DM型),330 Touch-15IKB(81DJ型)并运行以下操作系统:Windows 10(64 位) 再次感谢你的帮助。 请分享你的想法。 以上来自于谷歌翻译 以下为原文 Hello Juan, Thank you very much for the quick response. My BIOS has updated from AHSI to “Intel RST premium and system acceleration”. Yes, Lenovo advertised that this Laptop is Optane compatible. I actually downloaded the Optane Driver from their official website. I am using the Intel Optane Memory interface. laptops and netbooks :: 300 series :: 330 17ikb type 81dm :: 81dm :: 81dm001uus :: pf12vj93 Lenovo PC Support - us >> Storage >> This package provides Intel Rapid Storage Technology (IRST) Driver and is supported on 330-15IKB (Type 81DE), 330-17IKB (Type 81DM), 330 Touch-15IKB (Type 81DJ) and running the following Operating Systems: Windows 10 (64-bit) Thanks again for your help. Please share your thoughts. |
您好tarekc972,我已经研究过您的问题。如前所述,英特尔尚未测试任何联想主板,因为它与Optane配合使用。 但是,如果联想宣称您的笔记本电脑与Optane配合使用它应该可以工作。您是否尝试使用RST启用Optane内存? 您可以尝试通过此工具启用Optane。这是下载RST的链接:https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST-Under section 2.2 of 安装指南,您可以找到启用Optane的步骤.https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/optane-memory/intel-optane -memory-user-installation.pdf我们可以尝试这种可选方式来启用Optane。 这个程序不起作用你需要联系联想,一些原始设备制造商(OEM)有自己的程序来启用Optane。如果您有任何其他问题请告诉我。最好的问候,Juan N. 以上来自于谷歌翻译 以下为原文 Hello tarekc972, I have researched on your issue. As mentioned before Intel has not tested any Lenovo motherboard for it to work with Optane. However if Lenovo has advertised that your laptop works with Optane it should work. Have you attempted to use RST to enable the Optane memory? You can try to enable the Optane through this tool. Here is the link to download the RST: https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST- Under section 2.2 of the installation guide you can find the steps to follow to enable the Optane. https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/optane-memory/intel-optane-memory-user-installation.pdf We can try this optional way to enable your Optane. Is this procedure does not work you will need to contact Lenovo, some original equipment manufacturers (OEMs) have their own procedure to enable Optane. If you have any additional question let me know. Best Regards, Juan N. |
jerry1978 发表于 2018-11-27 11:08 您好tarekc972,您对此问题有任何其他疑问或反馈意见吗?最诚挚的问候,Juan N. 以上来自于谷歌翻译 以下为原文 Hello tarekc972, Do you have any additional question or feedback to provide about this issue? Best Regards, Juan N. |
572浏览 0评论
GMT+8, 2025-2-9 06:22 , Processed in 0.506902 second(s), Total 49, Slave 44 queries .
