它能以像素密度输出144Hz吗?
以上来自于谷歌翻译 以下为原文 Can it output 144Hz at that pixel density? |
4个回答
Hello Taba,感谢您加入此英特尔社区。我了解您希望以144 Hz刷新率设置2560x1440屏幕分辨率。
我想帮助你。为了提供更多相关信息,我们需要考虑其他因素,如处理器,图形控制器,甚至视频输出。请提供有关您的设置的以下信息.-品牌和型号 system.-Monitor(s)模型及其连接方式。另外,请运行英特尔®系统支持实用程序并将报告附加到此线程.1。下载英特尔®系统支持实用程序并将应用程序保存到系统中 .https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product = 916002.打开应用程序,然后单击扫描以查看系统和设备信息。 英特尔®系统支持实用程序默认为扫描后输出屏幕上的摘要视图。 单击其中显示摘要的菜单以更改为详细视图.3。要保存扫描,请单击“下一步”,然后单击“保存”。 您可以将文件保存到计算机上任何可访问的位置。要附加文件,必须单击响应框右上角的“使用高级编辑器”,然后右下角会出现“附加”选项 响应框的一角.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello Taba, Thank you for joining this Intel Community. I understand that you would like to set 2560x1440 screen resolution at 144 Hz refresh rate. I would like to assist you. In order to provide more information about this, we need to take into account other factors such as the processor, graphics controller, or even video output. Please provide the following information about your setup. -Brand and Model of the system. -Monitor(s) model and how it is connected. Also, please run the Intel® System Support Utility and attach the report to this thread. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box. Wanner G. |
jerry1978 发表于 2018-11-27 12:48 嘿嘿! 谢谢您的回复! 我想为办公室类型的任务购买桌面,现在在AMD Ryzen 2200G和Intel i3-8100系统之间进行选择。 所以这不是我所拥有的,而是我计划的东西=)但是为了体现我的计划,我必须在这两个系统之间做出选择。 我不会在那台机器上玩游戏或做任何图形密集的东西,但希望通过高刷新率监视器为我的界面添加平滑性。 我知道AMD APU在144Hz时能够达到2560x1440,但是找不到任何关于i3-8100 iGPU的信息,这是UHD 630。 所以回答你关于我正在使用的硬件的问题让它成为: 1)CPU - i3-8100 2)MB - 华硕Prime B360-plus(我希望从DVI-D输出输出144Hz) 3)监视器 - MSI Optix MAG27CQ 但我不能“运行英特尔®系统支持实用程序”,因为我没有那个硬件atm。 以上来自于谷歌翻译 以下为原文 Hey hey! Thank you for your reply! I want to purchase a desktop for office kind of tasks and now choosing between system on AMD Ryzen 2200G and Intel i3-8100. So this isn't what I have but something I'm planning to =) But in order to embody my plans I have to choose between these two systems. I won't game or do any kind of graphic intensive stuff on that machine but hope to add smoothness to my interface with high refresh rate monitor. I knew that AMD APU is capable of 2560x1440 at 144Hz but couldn't find any information about iGPU of i3-8100 which is UHD 630. So to answer your question about hardware I'm using let it be: 1) CPU - i3-8100 2) MB - Asus Prime B360-plus (I hope to output 144Hz from it DVI-D output) 3) Monitor - MSI Optix MAG27CQ But I can't "run the Intel® System Support Utility" since I don't have that hardware atm. |
您好Taba,感谢您的回复。基于您计划使用的硬件,由于主板限制,您可能无法达到2560x1440分辨率和144Hz刷新率。首先,我想确认英特尔®UHDGraphics 630支持 你想要达到的分辨率。 例如,它通过HDMI * 1.4支持4096x2304 @ 24Hz。 但是,根据您的主板规格,您可以通过HDMI * 1.4b通过DVI-D设置的最大分辨率为1920 x 1200 @ 60 Hz和4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz。 现在,基于以下关于HDMI *的信息(附件),您还必须考虑4:2:0子采样的帐户。我们建议您可以使用HDMI * 2.0视频输出来实现所需的分辨率和刷新率 没有任何硬件限制。附加处理器图形信息:https://ark.intel.com/products/126688/Intel-Core-i3-8100-Processor-6M-Cache-3_60-GHzAsus Prime B360-plushttps://www.asus .com / us /主板/ PRIME-B360-PLUS /规格/ Wanner G. HDMI 2.0.JPG 135.9 K. 以上来自于谷歌翻译 以下为原文 Hello Taba, Thank you for your response. Based on the hardware you are planning on using, you may not achieve 2560x1440 resolution and 144Hz refresh rate due to a motherboard limitation. First, I would like to confirm that Intel® UHD Graphics 630 supports the resolution you would like to achieve. For example, it supports 4096x2304@24Hz via HDMI* 1.4. However, according to your motherboard specifications, the maximum resolution you can set via DVI-D is 1920 x 1200 @ 60 Hz and 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz via HDMI* 1.4b. Now, based on the following information (attachment) about HDMI*, you also have to take into the account the 4:2:0 subsampling. Our recommendation is that you can use HDMI* 2.0 video output to achieve the resolution and refresh rate desired without any hardware limitation. Additional Processor Graphics information: https://ark.intel.com/products/126688/Intel-Core-i3-8100-Processor-6M-Cache-3_60-GHz Asus Prime B360-plus https://www.asus.com/us/Motherboards/PRIME-B360-PLUS/specifications/ Wanner G.
jerry1978 发表于 2018-11-27 13:14 我懂了。 非常感谢你! 以上来自于谷歌翻译 以下为原文 I've got it. Thank you very much! |
561浏览 0评论
GMT+8, 2025-2-3 05:44 , Processed in 0.643116 second(s), Total 81, Slave 65 queries .
