我最近为笔记本电脑扩展坞购买了两个Pavilion 23xw屏幕。
两个屏幕都设置为相同的屏幕分辨率设置,但是我的一个显示器上的屏幕超出了显示器(例如,我无法在任务栏中看到我的时钟或看到“x”到窗口屏幕) 。 我正在运行Windows 7并拥有一个英特尔高清显卡控制面板。 有什么建议么? 谢谢! 以上来自于谷歌翻译 以下为原文 I have recently purchased two Pavilion 23xw screens for my laptop docking station. Both of the screens are set to the same screen resolution settings however, the screen on only one of my monitors extends beyond the monitor (example, I can't see my clock in the task bar or see the "x" to window screens). I am running windows 7 and have an Intel HD Graphics Control Panel. Any suggestions? Thank you! |
您好hberning,感谢您加入英特尔社区。为了更好地帮助您,我想收集有关您在计算机中配置的更多信息。
请在.txt文件中附上.txt文件,英特尔®系统支持实用程序将生成https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility您正在使用的扩展坞的型号是什么? 让我也知道您在两台显示器中使用的视频电缆的类型。要附加文件,您必须单击响应框右上角的“使用高级编辑器”,然后“附加”选项将出现在 响应框的右下角.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello hberning, Thank you for joining the Intel Communities. In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility What is the model number of the docking station you are using? Let me also know the type of video cables you are using in both monitors. To attach a file, you must click “Use Advanced Editor” on the upper right hand corner of the response box, then the “attach” option will appear on the bottom right hand corner of the response box. Regards, Fred D. |
您好,我想知道您是否仍需要有关计算机中的过扫描问题的帮助。
如果你仍然需要帮助,请告诉我.Regards,Fred D. 以上来自于谷歌翻译 以下为原文 Hello hberning, I was wondering if you still need assistance regarding the overscan issue you were having in your computer. In case you still need assistance just let me know. Regards, Fred D. |
551浏览 0评论
GMT+8, 2025-1-26 14:36 , Processed in 0.561718 second(s), Total 79, Slave 63 queries .
