我们购买了二手MSO7000A,其中包含许多已安装的选件许可证,其中包括SEC选项,可防止将示波器设置持久保存到内部存储器。
当我连接它时,USB存储器似乎也没有显示为文件系统的一部分,所以基本上甚至没有一种不方便的方法来保存这台机器上的设置。 我们根本不需要SEC选项 - 有没有办法卸载它或以其他方式将其关闭? 以上来自于谷歌翻译 以下为原文 We purchased a used MSO7000A with many installed option licenses, including the SEC option which prevents persisting the scope settings to internal memory. It also appear that USB storage is not showing up as part of the filesystem either when I attach it, so basically there is not even an inconvenient way of saving the settings on this machine. We have no need for the SEC option at all here - is there a way to uninstall it or otherwise turn it off? |
5个回答
如果您可以禁用安全选项,那将不是非常安全,是吗?
以上来自于谷歌翻译 以下为原文 If you could disable the security option, that wouldn't be very secure,eh? |
理解,但即使在大型公司中,机器也可能被转移到不同的角色,而这样的安全性不是问题。 在我的工作中,我使用CAN和其他协议进行相当复杂的通道和触发设置。 每次关机时我都要从头开始 - 每一个设置都会丢失。 我想如果我可以从前一个所有者那里获得所有许可证密钥,那么可能有办法擦除所有许可证,然后重新安装除SEC之外的所有许可证。 以上来自于谷歌翻译 以下为原文 Understood, but even in a large company the machine may get moved into different roles where security like this isn't an issue. In my work I have fairly complex channel and triggering setups using CAN and other protocols. Every time I turn the machine off I have to start from scratch - every single setting is lost. I'm thinking that if I can get all of the license keys from the previous owner there could be a way to wipe all of the licenses and then reinstall everything but SEC. |
子璇ALICE 发表于 2018-11-26 13:58 擦除范围并从头开始可能有效,但我对此表示怀疑。 SEC选项旨在使其难以实现。 这是因为可能存在一些剩余数据,我们希望防范这一点。 我认为你唯一的选择是与你拥有的东西一起生活,或者购买另一个范围。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 Wiping the scope and starting from scratch, might work, but I doubt it. The SEC option is designed to make it hard to do that. That's specifically because there might, maybe, be some leftover data, and we want to guard against that. I think your only choices are to live with what you have, or buy another scope. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
这对我来说没有意义。 如果它有SEC选项,那么我认为它首先应该没有数据(剩余或其他)...... 以上来自于谷歌翻译 以下为原文 That does not make sense to me. If it has the SEC option, then I would think that it should have NO data (leftover or otherwise) on it in the first place... |
是的,但这不是安全人员的想法。 从他们的角度来看,总有这种可能性。 关键是SEC选项在这里是有原因的。 它无法删除。 如果可以将范围清回到SEC之前的状态,那么其他现有许可证也很可能无法使用。 当您购买二手设备时......免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 Yes, but that's not the way the security people think. From their point of view, there's always that possibility. The point is that the SEC option is here for a reason. It can't be removed. If it is possible to clear the scope back to pre-SEC status, then there's a good chance that the other existing licenses won't be available either. When you buy used equipment... Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1024 浏览 0 评论
2273 浏览 1 评论
2056 浏览 1 评论
1926 浏览 5 评论
2799 浏览 3 评论
797浏览 1评论
580浏览 0评论
676浏览 0评论
2462浏览 0评论
1519浏览 0评论
GMT+8, 2024-9-20 08:48 , Processed in 1.325374 second(s), Total 51, Slave 46 queries .
