再次CYW20706巫师,
对于我的项目,我必须从主机MCU通过不可靠的UART下载嵌入式应用程序(.HCD)到RAM。通过指南阅读似乎有两种方法来验证应用程序的下载没有被破坏:RAMMISRADE和CRC检查HCI命令。 CRC校验: 01立方厘米FC 08 XX XX XX YY YY YY YY 读随机存储器: 01 4D FC 05 XX XX XX YY YY 我的问题是,它们是否可以用于任何地址(RAM区域,而不是串行闪存)?还有其他方法来检查RAM吗? 谢谢! 以上来自于百度翻译 以下为原文 Hi again CYW20706 wizards, For my project I have to download embedded app (.hcd) to RAM through unreliable UART from the host MCU. Reading through the guide there seems to be two ways to verify the app download is not corrupted: RAM_READ and CRC check HCI commands. CRC check: 01 CC FC 08 xx xx xx xx yy yy yy yy READ_RAM: 01 4D FC 05 xx xx xx xx yy My question is can they be used for any address (RAM region rather than serial flash)? Are there any other ways to check RAM? Thanks! |
我已经测试了这两个命令,我认为答案是CRC校验在RAM上不起作用,但是Read SRAM工作(顾名思义,大惊喜)。由于HCI文档建议Read SRAM在Flash上工作,我想它可以在任何地址上工作。
以上来自于百度翻译 以下为原文 I have tested both commands and I think the answer is CRC check does not work on RAM, but READ_RAM works (as its name suggests, big surprise). Since HCI document suggest READ_RAM works on flash, I guess it would work on any address. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-25 07:43 , Processed in 0.669029 second(s), Total 44, Slave 39 queries .
