嗨,
我在计算机上安装ISE Design Suite 10.1后遇到了一些麻烦。 ISE Design suite 10.1已成功安装(也更新到sp3)。 但是,当我打开XPS工具时,我只能在右侧看到窗口的一小块区域(以下照片是屏幕快照)。 我必须单击鼠标右键并选择“浮动”选项,然后我才能看到整个屏幕。 我尝试再次安装软件,但情况是一样的。 这对我来说非常不方便,因为我每次都必须对每个窗口执行相同的操作。 有谁知道问题是什么? 我很感激一些帮助。 非常感谢。 以上来自于谷歌翻译 以下为原文 Hi, I suffered some troubles after I installed ISE Design suite 10.1 on my computer. The ISE Design suite 10.1 is installed successfully (also update to sp3). However, When I open the XPS tool, I can only see a small area of the window on the right side (the following photographs are the screen snapshot). I have to click the right button of mouse and choose the "float" option then I would be able to see the whole screen. I try to install the software again but the situation is the same. This is very inconvenient for me because I have to do the same action for each window each time. Does anyone know what the problem is? I'd appreciate some help. Thanks a lot. |
3个回答
其他人报告了某些Windows主题的类似问题:
http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270(无法正确查看窗口) BT 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Others have reported similar problems with certain Windows themes: http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270 (can't see windows correctly) bt View solution in original post |
http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270(无法正确查看窗口) BT 以上来自于谷歌翻译 以下为原文 Others have reported similar problems with certain Windows themes: http://forums.xilinx.com/xlnx/board/message?board.id=GenDis&message.id=270 (can't see windows correctly) bt
解决方案非常有用,而且很有效。
非常感谢。 以上来自于谷歌翻译 以下为原文 The solution is very helpful and it works. Thank you so much. |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1684浏览 1评论
441浏览 1评论
195浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 12:02 , Processed in 1.109657 second(s), Total 47, Slave 42 queries .
