加载最新的(12.3),当我运行xsetup(./xsetup)作为su我获得前两个ULUA,然后选择要安装的内容。
之后,当我单击下一步时,安装退出并且终端显示: ./xsetup:第32行:24372分段错误“$ setuploc / bin / lin / xsetup” 有人知道安装的内容吗? 我正在使用KDE4运行PclinuxOS 2010。 大量的RAM和硬盘空间。 希望我不是唯一有问题的人。 以上来自于谷歌翻译 以下为原文 Loaded the latest (12.3) and when I run xsetup (./xsetup) as su I get the first two ULUAs, then the selection of what to install. After that when I click next, the install exits and the terminal shows: ./xsetup: line 32: 24372 Segmentation fault "$setuploc/bin/lin/xsetup" Anybody know what is up with the install? I am running PclinuxOS 2010 with KDE4. Plenty of ram, and HDD space. Hope I am not the only one having an issue. |
我发现其他操作,如CUPS表现不佳(挂起,选项正常可用灰色),并且在重新安装CUPS的过程中,许多应用程序被Synaptic删除。
重新安装使我的系统在重新启动时无法启动。 所以我从头开始从Live CD重新安装操作系统。 ISE12.3安装在没有事件的情况下运行,IDE按预期运行。 我不知道错误配置的根本原因是什么,但是从头开始重新安装是痛苦但确定的。 以上来自于谷歌翻译 以下为原文 I found other operations such as CUPS that was behaving poorly (hanging, options nomally available greyed out) and in the process of re-installing CUPS many applications were removed by Synaptic. The re-install left my system unbootable upon restart. So I re-installed the OS from the Live CD from scratch. The ISE12.3 install ran without event and the IDE runs as expected. I do not know what the root cause of the bad configuration was but re-installation form scratch was painful but sure. |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2309浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 05:18 , Processed in 1.171455 second(s), Total 44, Slave 39 queries .
