大家好
我刚刚用新主板,cpu和ram更新了我5岁的系统。 我之前使用的是Gigabyte Z97X MB,配备Intel 4790K cpu和16 GB ddr3。 750固态硬盘在100%完美的时间内表现完美。 现在安装在带有AMD Ryzen 7 2700X和16Gb内存的MSI X470 mb上。 安装在唯一正确的pci-e插槽中,3号支持3Gen的xen。 然而750现在的巨大表现完全失败了 例如。 intertal transfer过去平均为400Mb / s,现在为35Mb / s。 运行ATTO测试时非常清楚。 8MB后驱动器“坏了” MSI支持只接受CrystalDisk,但在我看来,它给出了真实速度的错误图像。 有没有人见过这个? 谢谢 以上来自于谷歌翻译 以下为原文 Hello all I have just updated my 5 year old system with a new motherboard, cpu and ram. I used before a Gigabyte Z97X MB with a Intel 4790K cpu and 16 GB ddr3. The 750 SSD performed at 100% perfect the whole time. Now installed in a MSI X470 mb with a AMD Ryzen 7 2700X and 16Gb ram. Install in the only correct pci-e slot, number 3 supporting 3Gen at x4. However the great performance of the 750 is completely failed now Eg. intertal transfer used to be average 400Mb/s and is now 35Mb/s. It is very clear when running a ATTO test. after 8MB the drive is "broken" MSI support will only accept CrystalDisk, but in my opinion is gives a false image of the true speed. Has anyone seen this before? Thank you |
3个回答
您好a.nilsson。感谢您联系英特尔威廉希尔官方网站
支持。据我们了解,您更新了PC的某些部分,并且您希望从英特尔®SSD750系列获得类似或更好的性能,并且您正在寻找一些
有关性能的建议和信息。如果我们正确推断,请检查以下信息:•https://ark.intel.com/products/series/79678/Intel-SSD-750-Series具有特定的测试SSD的平均值 特定情况下的测试程序。 •请使用IOMeter工具按照以下链接中的步骤操作:https://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/***/intel_ssd_750_series_evaluation_guide_332075002us.pdfPlease 让我们知道结果。最好的问候,Josh B.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hello a.nilsson. Thank you for contacting Intel Technical Support. As we understand you updated some parts of your PC with newer parts and you were expecting to have a similar or better performance from your Intel® SSD 750 Series and you were looking for some recommendations and information regarding performance. If we inferred correctly please check the information below: • https://ark.intel.com/products/series/79678/Intel-SSD-750-Series has an average of the tested SSDs following a specific test procedure under specific circumstances. • Please, follow the procedure in the following link using the IOMeter tool: https://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/***/intel_ssd_750_series_evaluation_guide_332075002us.pdf Please let us know the results. Best regards, Josh B. Intel Customer Support |
jerry1978 发表于 2018-11-26 17:54 a.nilsson您好。感谢您联系了英特尔威廉希尔官方网站 支持。 自上次沟通以来,我们没有收到您的回复,我们想知道您是否需要进一步的帮助,或者我们是否可以结案;重要提示:如果需要进一步的帮助或澄清,如果您回复此帖子,我们将不胜感激。 除非您的询问完全不相关,否则不要写新的。 通过这种方式,我们将防止生成重复的帖子,我们不会失去思路。我们期待着您的回复。最好的问候,Josh B.Intel客户支持。 以上来自于谷歌翻译 以下为原文 Hello a.nilsson. Thank you for having contacted Intel Technical Support. We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case? Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought. We will be looking forward to your reply. Best regards, Josh B. Intel Customer Support. |
我有一个750 ssd。
这里结果相同。 我安装了以前的驱动器(3.2.0.1002)并解决了问题。 以上来自于谷歌翻译 以下为原文 I have a 750 ssd. Same results here. I installed the previous drive (3.2.0.1002) and solved the problem.
518浏览 0评论
GMT+8, 2024-12-24 11:16 , Processed in 0.712655 second(s), Total 52, Slave 46 queries .
