在这种情况下需要一些帮助:服务器有一个带有3 x 2 TB SATA驱动器的RAID5阵列两个驱动器在几秒钟内“失败”。
虚拟驱动器现在处于“离线”状态,因为3个驱动器中的2个驱动器处于脱机状态,当第一个驱动器发生故障时,虚拟驱动器变为降级,然后在20秒后,第二个驱动器被检测为“失败”,并且虚拟磁盘已从OFFLINE更改为DEGRADED建议 如何解决这个问题?RAID Controller是SROMBSASMR,机箱是SCAHSBPM1 谢谢 克林 以上来自于谷歌翻译 以下为原文 Need some help with this situation: the server has a RAID5 array with 3 x 2 TB SATA drives Two drives "failed" within seconds. The Virtual Drive is now "offline" since 2 drives out of 3 are offline the Virtual Drive became DEGRADED when the 1st drive failed, then after 20 seconds the second drive was detected as "failed" and the Virtual Disk was changed from OFFLINE to DEGRADED any suggestions how to troubleshoot this issue? RAID Controller is SROMBSASMR, the enclosure is SCAHSBPM1 thanks Calin |
您好,感谢您就我们的产品与我们联系。您要求的英特尔®集成RAID模块SROMBSASMR的交互式威廉希尔官方网站
支持已经停止。
我们可以通过我们的网站为您提供资源和自助服务支持信息。 我们高度建议您从产品支持网站获取信息https://communities.intel.com/community/tech/discontinued-products/https://www.intel.com/content/www/us/en/support/discontinued -products.htmland所有可用的威廉希尔官方网站 信息都包含在支持网站上。最好的问候, Emeth X. 以上来自于谷歌翻译 以下为原文 Hello, Thank you for contacting us about your product. The interactive technical support for the Intel® Integrated RAID Module SROMBSASMR you have requested has been discontinued. We can provide you with resources and self-service support information through our website. We highly suggest that you get information from the product support site https://communities.intel.com/community/tech/discontinued-products / https://www.intel.com/content/www/us/en/support/discontinued-products.html and all available technical information is included on the support site. Best Regards, Emeth X |
370浏览 0评论
GMT+8, 2024-9-21 00:38 , Processed in 0.749775 second(s), Total 75, Slave 59 queries .
