我有一个NUC8iHVK所以我可以做更多涉及图形处理。
我试图安装一个程序(BlueSkyPlan),它说我没有OpenGL 3.0支持,并且它需要运行该软件。 我试图更新驱动程序,但被告知它们是最新的。 然后我获得了英特尔系统扫描软件,这就是它所展示的内容。 操作系统:Microsoft Windows 10 Pro(10.0.17134 Build 17134) 物理内存(已安装):16 GB 处理器:Intel(R)Core(TM)i7-8809G CPU @ 3.10GHz 系统类型:基于x64的PC 已安装的更新总数:22个更新 - 有关详细信息,请参阅详细视图 显示适配器:英特尔(R)HD Graphics 630 23.20.16.4973 Microsoft Basic Display Adapter 10.0.17134.1 系统制造商:英特尔公司 系统型号:NUC8i7HVB 网络适配器:蓝牙设备(个人局域网)10.0.17134.1 英特尔(R)双频无线-AC 8265 20.50.0.4 英特尔(R)以太网连接(2)I219-LM 12.15.22.6 英特尔(R)I210千兆网络连接12.15.22.6 磁盘:Brother MFC-J985DW USB设备0.0字节(可用)10.0.17134.1 通用SU32G SD卡29.64 GB(可用)10.0.17134.1 WDC WDS500G2B0B-00YS70 399.18 GB(可用)10.0.17134.1 据我所知,8809g处理器只带有HVK型号,但扫描实用程序将我的系统显示为HVB型号,并且没有radeon图形。 我是否以某种方式在正确的方框中得到了错误的系统,或者是否需要采取措施来激活radeon图形? 谢谢, 布赖恩 以上来自于谷歌翻译 以下为原文 I got a NUC8iHVK so I could do some more involved graphic processing. I tried to install a program (BlueSkyPlan) and it said I didn't have OpenGL 3.0 support and that it was required to run the software. I tried to update the drivers but was told they were the most up to date. I then got the Intel system scan software and this is what it showed. Operating System: Microsoft Windows 10 Pro(10.0.17134 Build 17134) Physical Memory (Installed): 16 GB Processor: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz System Type: x64-based PC Total Installed Updates: 22 Updates - See Detailed View for more information Display Adapter(s): Intel(R) HD Graphics 630 23.20.16.4973 Microsoft Basic Display Adapter 10.0.17134.1 System Manufacturer: Intel Corporation System Model: NUC8i7HVB Network Adapter(s): Bluetooth Device (Personal Area Network) 10.0.17134.1 Intel(R) Dual Band Wireless-AC 8265 20.50.0.4 Intel(R) Ethernet Connection (2) I219-LM 12.15.22.6 Intel(R) I210 Gigabit Network Connection 12.15.22.6 Disk(s): Brother MFC-J985DW USB Device 0.0 bytes (available) 10.0.17134.1 Generic SU32G SD Card 29.64 GB (available) 10.0.17134.1 WDC WDS500G2B0B-00YS70 399.18 GB (available) 10.0.17134.1 As far as I know the 8809g processor only comes with the HVK model but the scan utility shows my system as an HVB model and there are no radeon graphics. Did I somehow get the wrong system in the correct box or is there something that needs to be done to activate the radeon graphics? Thanks, Brian |
4个回答
您好briandmiles,感谢您加入此英特尔社区。我了解您在打开应用程序时遇到Radeon™RX Vega M GH图形问题。
我想提供更多相关信息。根据所附报告,您的英特尔®NUC上未安装Radeon™RX Vega M GH的图形驱动程序。 在这种情况下,我们建议您可以为英特尔®高清显卡630执行图形驱动程序的全新安装,然后为集成和独立显卡安装最新的图形驱动程序。您可以按照以下步骤操作:1。断开设备与设备的连接 internet.2。卸载Intel Graphics驱动程序和Intel Display音频驱动程序。 为此,请按照以下链接中的以下链接中的步骤操作: - 通过设备管理器方法卸载英特尔图形驱动程序 - 通过设备管理器方法卸载英特尔®显示音频驱动程序或英特尔®HDMI音频驱动程序.https: //www.intel.com/content/www/us/en/support/articles/000005598/graphics-drivers.html3.Restart您的计算机。 转到设备管理器,检查Windows是否安装了其他版本的图形驱动程序。 如果是,请将其删除并重新启动计算机。 重复此过程,直到获得Microsoft Basic Display Adapter.4。 首先安装英特尔®高清显卡630的图形驱动程序.https://downloadcenter.intel.com/download/27894/Intel-Graphics-Driver-for-Windows-10?product = 98909重新启动系统。 然后,安装Radeon™RX Vega M GH Graphics的图形驱动程序.https://downloadcenter.intel.com/download/27894/Intel-Graphics-Driver-for-Windows-10?product = 1368666。一旦有最新的驱动程序 已安装,您可以再次启用互联网连接.Wanner G. 以上来自于谷歌翻译 以下为原文 Hello briandmiles, Thank you for joining this Intel Community. I understand that you are experiencing Radeon™ RX Vega M GH graphics issues when opening applications. I would like to provide more information about this. According to the report attached, the graphics driver for Radeon™ RX Vega M GH is not installed on your Intel® NUC. In this case, our recommendation is that you can perform a clean install of the graphics driver for Intel® HD Graphics 630 and then install the latest graphics driver for both integrated and discrete graphics. You can follow these steps: 1.Disconnect your unit from the internet. 2.Uninstall both the Intel Graphics driver and the Intel Display audio driver. To do this, please follow the steps on the link below under these sections: -Uninstalling the Intel Graphics Driver via the Device Manager Method -Uninstalling the Intel® Display Audio Driver or the Intel® HDMI Audio Driver via the Device Manager Method. https://www.intel.com/content/www/us/en/support/articles/000005598/graphics-drivers.html 3.Restart your computer. Go to the device manager and check if Windows installed another version of the graphics driver. If it does, please remove it and restart your computer one more time. Repeat the process until you get the Microsoft Basic Display Adapter. 4. Install the graphics driver for Intel® HD Graphics 630 first. https://downloadcenter.intel.com/download/27894/Intel-Graphics-Driver-for-Windows-10?product=98909 Reboot your system. 5. Then, install the graphics driver for Radeon™ RX Vega M GH Graphics. https://downloadcenter.intel.com/download/27894/Intel-Graphics-Driver-for-Windows-10?product=136866 6.Once the latest driver has been installed, you may enable the internet connection again. Wanner G. |
jerry1978 发表于 2018-11-26 17:07 您知道,NUC8i7HVB是NUC8i7HVK NUC中使用的电路板(基板,主板,无论您想要调用它)的标识符。 字符串中的'B'表示板。 'K'表示它是一个带有薄型底盘的套件(相应的'H',您将看到其他更标准的NUC型号(例如NUC7i7BNH)表示一个具有更高轮廓的套件 机箱; SATA驱动器托架需要更高的配置文件)。 由于NUC8i7HVK作为套件发货(即您必须自己添加内存,存储和O / S)而不是作为完整系统,因此仅为电路板提供SMBIOS字符串; 它们不是为机箱或整个系统提供的(尽管您可以使用intel Integrator Toolkit自行添加这些字符串)。 内容S 以上来自于谷歌翻译 以下为原文 Just so you know, NUC8i7HVB is the identifier for the board (baseboard, motherboard, whatever you want to call it) that is used in the NUC8i7HVK NUC. The 'B' in the string indicates board. The 'K' indicates that it is a kit with a low-profile chassis (the corresponding 'H' that you will see with other, more-standard NUC models (like the NUC7i7BNH, for example) indicates a kit with a higher-profile chassis; the higher profile being necessary for the SATA drive bay). Since the NUC8i7HVK ships as a kit (i.e. you have to add memory, storage and O/S yourself) and not as a full system, SMBIOS strings are provided only for the board; they are not provided for the chassis or the overall system (though you can add these strings yourself using intel Integrator Toolkit). ...S |
Hellobriandmiles,我希望您发现此主题提供的信息很有帮助。如果您仍需要任何帮助,我们将很乐意为您提供帮助.Wanner G.
以上来自于谷歌翻译 以下为原文 Hello briandmiles, I hope you found the information provided on this thread helpful. If you still need any assistance, we will be glad to help you. Wanner G. |
嗨布莱恩,
我有一个NUC8i7HVK,并确认BlueSky安装并运行正确的Radeon驱动程序。 以上来自于谷歌翻译 以下为原文 Hi Brian, I have a NUC8i7HVK, and confirm that BlueSky does install and run with the correct Radeon driver. |
GMT+8, 2025-7-8 14:38 , Processed in 0.800845 second(s), Total 79, Slave 63 queries .
