我们是根据自己的特点制造自己的柏树狗
HTTP://www. CyPress .com /文档/开发-KITSBBOARDS/CY5670CySMART-UB-GELE, 我想知道我们是否需要任何外部程序员将HEX文件烧到加密狗,或者它可以通过PSoC程序员的USB端口来完成? 我们也有CY8CKIT-042-BLE套件与我们,我们可以使用该套件来编程CY5670BLE USB软件狗? 以上来自于百度翻译 以下为原文 We are manufacturing our own Cypress ble dongle according to the link http://www.cypress.com/documenta ... cysmart-u***-dongle, I want to know whether we need any external programmer to burn the hex file to the dongle or it can be done through USB port from PSOC programmer? We also have CY8CKIT-042-BLE kit with us, can we use that kit to program the CY5670 ble u*** dongle? |
正如你所看到的,有两个PSOC在软件狗上,一个PRO4为BLE设备,一个PSoC5LP作为程序员和USB接口。当您不需要(重新)编程您的BLE设备在该领域中,您可以跳过程序员,包括由PSoC5LP管理的USB接口。你需要一个MixPrim3或KiTrg来编程工厂的BLE。
使用CyPress提供的KITPROG软件和使用KiTrPG或MIXPROP3编程,可以用KITPROG软件编程PSOC5LP。 鲍勃 以上来自于百度翻译 以下为原文 As you can see there are two PSoCs on the dongle, A PRoc4 as BLE device and a PSoC5lP as programmer and USB interface. When you do not need to (re-)program your BLE device in the field, you may skip the programmer including the USB interface which is managed by the PSoC5LP. You will need a Miniprog3 or a kitprog to program the BLE at the factory. Programming the PSoC5LP with the kitprog software can be done with the cypress provided kitprog software and using a kitprog or Miniprog3 Bob |
764个成员聚集在这个小组
加入小组2200 浏览 1 评论
1945 浏览 1 评论
3769 浏览 1 评论
1868 浏览 6 评论
1610 浏览 1 评论
1314浏览 2评论
687浏览 2评论
518浏览 2评论
497浏览 2评论
1373浏览 2评论
GMT+8, 2025-4-19 01:59 , Processed in 0.897008 second(s), Total 45, Slave 39 queries .
