我Flash/EE 存储器进行读写,之前出现过能观看寄存器正确操作写入0X55AA 然后同样的地址读出来为0XFFFF
(错误值)。经过测试一段时间后重新建立工程,就出现了正确读到0X55AA的情况 。然后昨天又出现了读出的是OXFFFF 的情况,对于手头项目比较紧张,希望ADI公司能尽快帮我解决问题。附带FLASH 操作基本程序 unsigned short Flash_Red(unsigned short FlashAddr) { unsigned short FlashData; unsigned char Status; FEEMOD=FEEMOD|0x8; //Erase key enable FEEADR=FlashAddr; FEECON=READ_HALF_WORD; Status = FEESTA&0x03; while (!(Status)) Status = FEESTA&0x03; if ((Status&0x02)==0x02) ERROR = 1; FlashData=FEEDAT; FEEMOD&=0xfff7; //Erase key unable return FlashData; } void ErasePage(unsigned short FlashAddr ) { unsigned char Status; FEEMOD=FEEMOD|0x8; //Erase key enable FEEADR=FlashAddr; FEECON=ERASE_PAGE; Status = FEESTA&0x03; while (!(Status)) Status = FEESTA&0x03; if ((Status&0x02)==0x02) ERROR = 1; FEEMOD&=0xfff7; //Erase key unable } void Flash_Write (unsigned short FlashAddr,unsigned short FlashData) { unsigned char Status; FEEMOD=FEEMOD|0x8; //Erase/Red key enable FEEADR=FlashAddr; FEEDAT=FlashData; FEECON=WRITE_HALF_WORD; Status = FEESTA&0x03; while (!(Status)) Status = FEESTA&0x03; if ((Status&0x02)==0x02) ERROR = 1; FEEMOD&=0xfff7; //Erase key unable } |
2300个成员聚集在这个小组
加入小组1149 浏览 2 评论
1507 浏览 2 评论
2025 浏览 1 评论
4342 浏览 2 评论
9172 浏览 1 评论
1892浏览 3评论
1785浏览 2评论
1149浏览 2评论
1794浏览 2评论
1507浏览 2评论
GMT+8, 2025-3-7 09:00 , Processed in 0.639936 second(s), Total 42, Slave 37 queries .
