嗨,
我好像已正确安装了ISE Design Suite软件。 使用Centos 5 Red Hat。 我希望我会在Centos 5中看到ICON。没有。 所以我不知道该怎么做 EDK和ISE正在运行。 谢谢, 加里 以上来自于谷歌翻译 以下为原文 Hi, I seemed to have installed the software ISE Design Suite correctly. Using Centos 5 Red Hat. I was hoping I would see ICONs in Centos 5. Did not. So I don't know how to get EDK and ISE running. Thank You, Gary |
嗨加里,
您可以访问Xilinx ISE安装目录(例如/opt/Xilinx/13.2/ISE_DS),并运行以下命令来设置ISE工具环境。 source settings32(64).csh(对于tcsh SHELL) source settings32(64).sh(对于bash SHELL) 然后键入'ise'或'xps'以启动ISE或EDK GUI。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Hi Gary, You can go to Xilinx ISE installation directory (e.g. /opt/Xilinx/13.2/ISE_DS), and run the following command to set up ISE tools environment. source settings32(64).csh (for tcsh SHELL) source settings32(64).sh (for bash SHELL) Then type 'ise' or 'xps' to start ISE or EDK GUI. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1384浏览 1评论
596浏览 1评论
461浏览 1评论
2014浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 16:05 , Processed in 1.054757 second(s), Total 48, Slave 42 queries .
