你好,
我试图在我的aero上写一些python 3代码,但我似乎无法通过dnf得到pip3。 在aero(股票yocto)上有python 3,默认(也是唯一)pip用于python 2.是否有我可以添加的存储库来获取pip3? 我试图从源代码构建,但我缺少位于python-dev中的文件,这些文件也不能通过dnf获得。 谢谢, 山塔努 以上来自于谷歌翻译 以下为原文 Hello, I am trying to write some python 3 code on my aero but I can't seem to get pip3 through dnf. There is python 3 on the aero (stock yocto) and the default (and only) pip is for python 2. Are there repositories I can add to get pip3? I attempted to build from source but I'm missing files that are located in python-dev which is also not available through dnf. Thanks, Shantanu |
Helloshantanuv,我们已收到你的提议,我们正在调查此事项。我们收到回复后,我们会尽快回复你。谢谢你,Eliza
以上来自于谷歌翻译 以下为原文 Hello shantanuv, We have received your request and we are currently investigating it. As soon as we have a response, we will get back at you. Thank you, Eliza |
jerry1978 发表于 2018-11-23 13:44 Helloshantanuv,你的问题听起来非常类似于以下主题:https://communities.intel.com/thread/128373你是否介意我们在同一个线程上回答你的问题以避免冗余?谢谢你,Eliza 以上来自于谷歌翻译 以下为原文 Hello shantanuv, Your issue sounds very similar to the following thread: https://communities.intel.com/thread/128373 Do you mind if you we answer your question on the same thread to avoid redundancy? Thank you, Eliza |
GMT+8, 2025-4-24 19:10 , Processed in 0.823052 second(s), Total 98, Slave 82 queries .
