自从我实施VROC以来,Windows每周一次或两次崩溃。
Microsoft尚未安装修补程序。 英特尔是否有办法解决这个问题? 0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL iaVroc.sys https://support.microsoft.com/en ... a-bugcheck-when-you 主板型号和制造商:华硕横冲直撞VIP处理器型号:I9 7960x已安装的RAM:32gb 4133mhz ddr 4 corsairNumer存储设备及其容量(SSD和HDD)在您的机器上:2x 16x asus超级卡8x intel 760p m。 2和dimm2 2x intel 760p m.2总计10x intel 760 m.2驱动器用于RAID(0,1,5,10)配置?:1x raid 10和3x raid 1 以下小型转储仅显示最近2个事件。 附上Vroc日志。 IntelME_MSI.log.zip 175.5 K. 以上来自于谷歌翻译 以下为原文 Windows crashes by itself once or twice a week since I implemented VROC. Microsoft doesn't have hotfix yet. Does Intel have something to fix this problem ? 0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL iaVroc.sys https://support.microsoft.com/en ... a-bugcheck-when-you
following mini dump is only show last 2 events. Vroc log is attached.
4个回答
None
以上来自于谷歌翻译 以下为原文 Sstem Report System Information OS name: Microsoft Windows Server 2012 R2 Standard OS version: 6.3.9600 System name: SERVER1 System manufacturer: System manufacturer System model: System Product Name Processor: GenuineIntel Intel64 Family 6 Model 85 Stepping 4 2.801 GHz BIOS: American Megatrends Inc., 1401 Intel® Rapid Storage Technology enterprise Information User interface version: 5.3.0.1412 Language: English (United States) Intel controller: VMD Number of NVMe ports: 10 Intel controller: SATA (AHCI) Number of SATA ports: 8 RAID option ROM version: 5.3.0.1052 Driver version: 5.3.0.1388 VMD driver version: 5.3.0.1388 ISDI version: 5.3.0.1412 Storage System Information RAID Configuration Array Name: NVMe_Array_0000 Size: 488,396 MB Available space: 24,428 MB Number of volumes: 1 Volume member: 1Raid10D Number of array disks: 2 Array disk: BTHH815608CK256B Array disk: BTHH815609RC256B Array Name: NVMe_Array_0001 Size: 488,396 MB Available space: 24,428 MB Number of volumes: 1 Volume member: 2Raid10D Number of array disks: 2 Array disk: BTHH75130X0M256B Array disk: BTHH815609E4256B Array Name: NVMe_Array_0002 Size: 1,953,544 MB Available space: 97,694 MB Number of volumes: 1 Volume member: Raid10C Number of array disks: 4 Array disk: BTHH82050RTN512D Array disk: BTHH82050V3H512D Array disk: BTHH82050RUG512D Array disk: BTHH82050UNW512D Array Name: NVMe_Array_0003 Size: 488,396 MB Available space: 24,428 MB Number of volumes: 1 Volume member: 3Raid10D Number of array disks: 2 Array disk: BTHH815609YE256B Array disk: BTHH815609PC256B Volume name: 1Raid10D Status: Normal Type: RAID 1 Size: 231,983 MB System volume: No Data stripe size: N/A Initialized: Yes Blocks with media errors: 0 Physical sector size: 512 Bytes Logical sector size: 512 Bytes Volume name: 2Raid10D Status: Normal Type: RAID 1 Size: 231,983 MB System volume: No Data stripe size: N/A Initialized: Yes Blocks with media errors: 0 Physical sector size: 512 Bytes Logical sector size: 512 Bytes Volume name: Raid10C Status: Normal Type: RAID 10 Size: 927,923 MB System volume: Yes Data stripe size: 64 KB Initialized: Yes Blocks with media errors: 0 Physical sector size: 512 Bytes Logical sector size: 512 Bytes Volume name: 3Raid10D Status: Normal Type: RAID 1 Size: 231,983 MB System volume: No Data stripe size: N/A Initialized: Yes Blocks with media errors: 0 Physical sector size: 512 Bytes Logical sector size: 512 Bytes Hardware Information Controller name: Intel(R) VROC (Intel-SSD-only) Type: VMD Mode: RAID Number of volumes: 4 Volume: 1Raid10D Volume: 2Raid10D Volume: Raid10C Volume: 3Raid10D Number of spares: 0 Number of available disks: 0 Rebuild on Hot Insert: Disabled Manufacturer: 8086 Model number: 201D Product revision: 4 Direct attached disk: BTHH815608CK256B Direct attached disk: BTHH815609RC256B Direct attached disk: BTHH75130X0M256B Direct attached disk: BTHH815609E4256B Direct attached disk: BTHH82050RTN512D Direct attached disk: BTHH82050V3H512D Direct attached disk: BTHH82050RUG512D Direct attached disk: BTHH82050UNW512D Direct attached disk: BTHH815609YE256B Direct attached disk: BTHH815609PC256B Controller name: Intel(R) C600+/C220+ series chipset SATA AHCI Controller Type: SATA Mode: AHCI Number of volumes: 0 Number of spares: 0 Number of available disks: 6 Rebuild on Hot Insert: Disabled Manufacturer: 8086 Model number: A282 Product revision: 0 Direct attached disk: BTLA8054085K256CGN Direct attached disk: BTLA805200UM256CGN Direct attached disk: BTLA8051062P256CGN Direct attached disk: BTLA80530BVE256CGN Direct attached disk: BTLA80510FPF256CGN Direct attached disk: BTLA805201QW256CGN Disk on Controller 0, Port 0 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH815608CK256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 0, Port 1 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH815609RC256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 0, Port 2 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH75130X0M256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 0, Port 3 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH815609E4256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 1, Port 0 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 477 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW512G8 Serial number: BTHH82050RTN512D SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 1, Port 1 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 477 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW512G8 Serial number: BTHH82050V3H512D SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 1, Port 2 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 477 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW512G8 Serial number: BTHH82050RUG512D SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 1, Port 3 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 477 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW512G8 Serial number: BTHH82050UNW512D SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 2, Port 0 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH815609YE256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 2, Port 1 Status: Normal Type: NVMe SSD Location type: Internal Usage: Array disk Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: None Model: INTEL SSDPEKKW256G8 Serial number: BTHH815609PC256B SCSI device ID: 0 Firmware: 001C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 2 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA8054085K256CGN SCSI device ID: 2 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 3 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA805200UM256CGN SCSI device ID: 3 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 4 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA8051062P256CGN SCSI device ID: 4 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 5 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA80530BVE256CGN SCSI device ID: 5 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 6 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA80510FPF256CGN SCSI device ID: 6 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Disk on Controller 3, Port 7 Status: Normal Type: SATA SSD Location type: Internal Size: 238 GB System disk: No Disk data cache: Enabled Command queuing: NCQ Model: INTEL SSDSC2KW256G8 Serial number: BTLA805201QW256CGN SCSI device ID: 7 Firmware: LHF002C Physical sector size: 512 Bytes Logical sector size: 512 Bytes Empty port Port: 0 Controller SATA (AHCI) Port location: Internal Empty port Port: 1 Controller SATA (AHCI) Port location: Internal |
您好Danone。感谢您与英特尔威廉希尔官方网站 支持联系。根据您与我们分享的配置,我们发现了以下信息: 主板型号和制造商:Asus rampage extreme VI是一款游戏主板,它不是用作服务器主板。 华硕rampage extreme VI旨在与Windows®1064位一起使用,并且有一些驱动程序可用于其他较旧的操作系统(OS),它们都不是服务器分发版。 英特尔®SSD760p系列未经过测试或验证,无法与您的华硕extreme VI主板(基于英特尔®产品兼容性工具)配合使用。 英特尔®SSD760p系列并非设计用于数据中心环境,而且会使SSD保修失效。 英特尔®测试或验证华硕Hyper M.2 X16卡不支持与我们的M.2设备一起使用。据说英特尔®不支持您当前的配置,预计会遇到错误.0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL 您提到的iaVroc.sys错误与您在系统上的特定操作系统有关,而且Microsoft目前正在开发解决方案,而英特尔没有针对它的特定解决方案。我们唯一的建议是等待此线程的更新 :https://support.microsoft.com/en-us/help/2916984/stop-error-0x000000d1-and-windows-server-2012-runs-a-bugcheck-when-you我们希望您发现此信息有用。谢谢 您的耐心和理解。最好的问候,Josh B.Intel客户支持 以上来自于谷歌翻译 以下为原文 Hello Danone. Thank you for contacting Intel Technical Support. Based on the configuration you shared with us we found the following information:
This being said your current configuration is not supported by Intel® and it is expected to experience errors. The 0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL iaVroc.sys error as you mentioned is related to the specific OS you have on your system and Microsoft is currently working on a solution and Intel® does not have a specific solution for it. Our only recommendation is to wait for an update on this thread: https://support.microsoft.com/en-us/help/2916984/stop-error-0x000000d1-and-windows-server-2012-runs-a-bugcheck-when-you We hope you find this information useful. Thank you for your patience and understanding. Best regards, Josh B. Intel Customer Support |
jerry1978 发表于 2018-11-23 11:41 您好Danone。感谢您联系了英特尔威廉希尔官方网站 支持。 自上次沟通以来,我们没有收到您的回复,我们想知道您是否需要进一步的帮助,或者我们是否可以结案;重要提示:如果需要进一步的帮助或澄清,如果您回复此帖子,我们将不胜感激。 除非您的询问完全不相关,否则不要写新的。 通过这种方式,我们将防止生成重复的帖子,我们不会失去思路。我们期待着您的回复。最好的问候,Josh B.Intel客户支持。 以上来自于谷歌翻译 以下为原文 Hello Danone. Thank you for having contacted Intel Technical Support. We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case? Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought. We will be looking forward to your reply. Best regards, Josh B. Intel Customer Support. |
cd340823 发表于 2018-11-23 11:55 嗨Josh, 我通过在intel快速存储软件中启用磁盘缓存来解决问题。 已经1个月零1周我没有任何崩溃,到目前为止没有任何问题。 谢谢 以上来自于谷歌翻译 以下为原文 Hi Josh, I solved issue by enabling disk cache in intel rapid storage software. it has been 1 month and 1 week I don't have any crashes and no problem so far. Thanks |
519浏览 0评论
GMT+8, 2024-12-25 12:56 , Processed in 0.780153 second(s), Total 82, Slave 66 queries .
