大家好,
我计划生成我的Hex文件的CRC计算,我想将CRC保存在生成的hex文件的最终内存位置, SPCstudio中是否有任何选项可以使用CRC,这样当IDE生成hex文件时,它可以计算CRC并将其保存在生成的Hex文件的结束位置, 在闪存到电路板时,我们可以删除CRC字节并闪存hex文件, 请告诉我在SPCstdio中是否有任何启用选项。 提前致谢, --- 谢谢&问候, Mujeeb #crc#spc5 以上来自于谷歌翻译 以下为原文 Hi All, I am planning to have CRC calculation for my Hex file generated and i want to keep that CRC at the end memory location of hex file generated , Is there any option in SPCstudio to enbale CRC so that when IDE is generating hex file it can calculate the CRC and keep it at the end location of the generated Hex file, while flashing to the board we can remove that CRC bytes and flash the hex file, Please let me know is there any option to enable in SPCstdio. Thanks in advance, --- Thanks & Regards, Mujeeb #crc #spc5 |
3个回答
你好Mujeeb,
抱歉,我们在SPC5Studio中没有测试应用程序,它会生成hex文件的校验和。 我会使用srecord。 https://mcuoneclipse.com/2015/04/26/crc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse/ http://www.avrfreaks.net/forum/tutgccadding-crc-and-app-length-hex-files 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Mujeeb , Sorry, we have not a test application in SPC5Studio which generates the checksum of the hex file. i would use srecord for that. https://mcuoneclipse.com/2015/04/26/crc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse/ http://www.avrfreaks.net/forum/tutgccadding-crc-and-app-length-hex-files Best regards Erwan |
嗨二湾,
感谢您的答复, 根据我的理解,Srecord是单独的实用程序,如何将此实用程序添加到SPCstdio,如果无法添加我们如何使用srecord standalone, 在链接中提供的任何内容( /external-link.jspa?url=https%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F )是针对Kinetis Design Studio(MCU是基于ARM的)但是在我的情况下SPC560B不是基于ARM的,所以如何使用Srecord for SPC560B系列不是基于ARM的,请你在这方面帮助我,这对我来说真的很有帮助我。 提前致谢, 谢谢&问候, Mujeeb。 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi Erwan, Thanks for your response, As per my understanding Srecord is separate utility,How to add this utility to SPCstdio,if it is not possible to add how we can use srecord standalone, In link whatever provided by you ( /external-link.jspa?url=https%3A%2F%2Fmcuoneclipse.com%2F2015%2F04%2F26%2Fcrc-checksum-generation-with-srecord-tools-for-gnu-and-eclipse%2F )is for Kinetis Design Studio(MCU is ARM based) but in my case SPC560B is not ARM based so how to use Srecord for SPC560B family which is not ARM based can you please help me in this regards,it will be really very helpful to me. Thanks in advance, Thanks & Regards, Mujeeb. Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
你好Mujeeb,
对于此任务,您需要一个单独的实用程序来计算校验和,并通过在链接过程中更新makefile来将其重新集成到elf中。 它与MPC56的精神相同 https://community.nxp.com/docs/DOC-329541 在二进制目录(freevle-gcc插件)中,您可以使用所有工具。 (使用objcopy) http://stackoverflow.com/questions/24150030/storing-crc-into-an-axf-elf-file 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Mujeeb , For this task , you need a separate utility to calculate a checksum and to reintegrate it in the elf by updating your makefile during link procedure. it is the same spirit for MPC56 https://community.nxp.com/docs/DOC-329541 in the binary directory (freevle-gcc plugins) you have all the tools to do that. (use objcopy) http://stackoverflow.com/questions/24150030/storing-crc-into-an-axf-elf-file Best Regards Erwan |
2823 浏览 1 评论
3263 浏览 1 评论
1840 浏览 1 评论
3689 浏览 6 评论
6092 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
391浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
481浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
312浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
228浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
334浏览 2评论
GMT+8, 2025-2-1 14:59 , Processed in 0.965751 second(s), Total 48, Slave 43 queries .
