嗨,
我正在研究在未来的项目中使用LSM6DSL(以取代我们对LSM6DS3的使用),我一直在测试STEVAL-MKI178V1评估部分。 在加速度计的Z轴上似乎有一些奇怪的信号(旧的LSM6DS3上没有),? 我已经将来自6个轴(gyro_x,gyro_y,gyro_z,accel_x,accel_y,accel_z)的30s测量数据的图片与3个不同方向的传感器相连。流氓信号的强度似乎总是恒定的(大约100 LSB,或者我们的规模为6 mg)。 传感器配置为高性能模式,104 Hz输出数据速率,+ -2g满量程。 谢谢, 缺口 #lsm6dsl #accelerometer 以上来自于谷歌翻译 以下为原文 Hi, I'm investigating the use of the LSM6DSL in a future project (to replace our use of the LSM6DS3) and I have been testing the STEVAL-MKI178V1 evaluation part. There appears to be some strange signal on the Z axis of the accelerometer (that was not present on the older LSM6DS3), ? I've attached pictures of 30s of measurement data from the 6 axes (gyro_x, gyro_y, gyro_z, accel_x, accel_y, accel_z) with the sensor in 3 different orientations. The strength of the rogue signal always seems to be constant (around 100 LSB, or 6 mg at our scale). The sensor is configured to be in high performance mode, 104 Hz output data rate, +-2g full scale. Thanks, Nick #lsm6dsl #accelerometer |
5个回答
这是出乎意料的行为。你在使用FIFO吗?
你有另一件要试试吗? 以上来自于谷歌翻译 以下为原文 It is unexpected behavior. Are you using FIFO? Do you have another piece to try? |
你好Miroslav,
是的我正在使用FIFO,我每1秒清空一次,这对应于信号的衰减。我只购买了一个部件用于评估目的,所以我没有任何替代硬件可供尝试。 以上来自于谷歌翻译 以下为原文 Hi Miroslav, Yes I am using the FIFO, and I am emptying it every 1 second which corresponds to the decay of the signal. I only purchased a single part for evaluation purposes so I do not have any alternative hardware to try. |
我认为传感器配置会出现问题。在我看来,时间戳数据被添加到Z轴数据,因此它创建了锯形信号。你能分享你的传感器配置吗?我可以尝试复制这个问题。
以上来自于谷歌翻译 以下为原文 I think there will be something wrong in the sensor configuration. It seems to me that timestamp data are added to the Z axis data, so it creates the saw shape signal. Can you please share your sensor configuration? I can try to replicate the issue. |
你好尼克,
你解决了问题了吗?我问,因为我有类似的问题。 Br Piotr 以上来自于谷歌翻译 以下为原文 Hello Nick, Did you solved your issue? I'm asking because i have similar problem. Br Piotr |
2827 浏览 1 评论
3267 浏览 1 评论
1844 浏览 1 评论
3693 浏览 6 评论
6098 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
395浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
487浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
316浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
235浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
339浏览 2评论
GMT+8, 2025-2-3 08:17 , Processed in 1.057522 second(s), Total 50, Slave 45 queries .
