大家好,我刚刚买了一台DSO1072B示波器,它工作正常,但液晶显示器的通道颜色在我看来有点奇怪,因为CH1不是黄色(看起来像偏红)而CH2不是绿色(它是
由于低对比度,它们难以阅读。 但是当我保存波形并在计算机上打开它时,如同附加的那样,颜色是正确的。 有没有办法在软件中解决这个问题? 或者我是否需要联系威廉希尔官方网站 支持? 谢谢, 以上来自于谷歌翻译 以下为原文 Hi everyone, I just bought a DSO1072B Oscilloscope and it is working fine, but the LCD display colors of the channels seems to me a little bit odd, since CH1 is NOT yellow (it seem like reddish) and CH2 is NOT green (it is a little bit blueish) and they are hard to read due to low contrast. But when I save the waveform and open it on the computer, as the one attached, the colors are right. Is there a way to fix that in software? Or will I have to contact technical support? Thanks, 附件
与威廉希尔官方网站
支持联系。
可能是硬件问题(松散的电线?)。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 Get in touch with Technical Support. Probably a HW problem (loose wire?). Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1425浏览 1评论
827浏览 0评论
1195浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 15:52 , Processed in 1.411457 second(s), Total 76, Slave 60 queries .
