我使用CY8CITK-062-BLE,并编写了与CySMART Android应用程序通信的小基本代码。在实现代码时,我意识到“CythBuryEvtGAPpDeice连接”事件不是由PSoC6堆栈生成的。我通过同样的工具包实现了“CE212736PPSO6BLYFIDEME01”项目,通过启用UART调试证实了这一点。因此,我在代码中使用“CythBuryEvtgGATHEngultCytEngIn”事件检查连接状态,如本讨论中附带的项目所示。
请确认我的项目代码是否有错误,或者在PSOC6BLE中产生一些其他的方法,其中“CythBuryEvtEngpApDigice连接”事件是在PSOC6BLE中生成的。 PoS66I. 9.2兆字节 以上来自于百度翻译 以下为原文 I am using CY8CKIT-062-BLE and has written small basic code for communication with CySmart android application. while implementing code I realised that "CY_BLE_EVT_GAP_DEVICE_CONNECTED" event is not generated by PSoC6 stack. I confirmed the same by implementing project "CE212736_PSoC6BLE_FindMe01" given by cypress in same kit by enabling UART debugging. Hence I am using "CY_BLE_EVT_GATT_CONNECT_IND" event in code to check connection status as shown in project attached with this discussion. Please confirm whether something wrong with my project code or else there some other method where "CY_BLE_EVT_GAP_DEVICE_CONNECTED" event is generated in PSoC6 BLE. |
你好,RAutStIN 2245351,
请注意,只有当“链接层隐私”被禁用时,才生成“CythBuryEvtGAPpDeice连接”事件。这可以通过取消组件“链接层设置”选项卡中的“启用链接层隐私”选项来完成。 话虽如此,当启用了LL隐私时,生成了“CythBuryEvtgGAPHyHangShan-CurnOffult”事件而不是此事件。原因是两个参数都稍微不同,传递给处理程序。您可以使用下面的代码自动地使用事件的任何一个,这取决于应用程序中是否启用了LL隐私。 如果(CythBulyLLL PrimaYyLyStudio启用) 病例: { CysStCyBuffggpHythangsN-CalnExcel =(CysStCyBulgGAPHyHangShan-CalnExcel)PARAMAMT**事件PARAMAM; 否则 Cyb BuryEvtggpAPI Digice连接: { CysStCYBLIGGAPLICONDATION PARAMT**连接参数 =(CysStCyBulgGAPLCONTIDEND PARAMOT**)EVER PARAM; 第二节 让我知道这是否有帮助。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Hello rautinst_2245351, Please note that "CY_BLE_EVT_GAP_DEVICE_CONNECTED" event is generated only when "Link Layer privacy" is disabled. This can be done by unchecking the "Enable Link layer privacy" option in component's "Link layer Settings" tab. Having said that, when LL privacy is enabled, instead of this event "CY_BLE_EVT_GAP_ENHANCE_CONN_COMPLETE" event is generated. The reason is both have a slightly different parameters that is passed to the handler. You can use the below code to automatically use either of the event depending on if LL privacy is enabled or not in your application. #if(CY_BLE_LL_PRIVACY_FEATURE_ENABLED) case CY_BLE_EVT_GAP_ENHANCE_CONN_COMPLETE: { cy_stc_ble_gap_enhance_conn_complete_param_t *connParameters = (cy_stc_ble_gap_enhance_conn_complete_param_t *)eventParam; #else case CY_BLE_EVT_GAP_DEVICE_CONNECTED: { cy_stc_ble_gap_connected_param_t *connParameters = (cy_stc_ble_gap_connected_param_t *)eventParam; #endif Let me know if this helps. Regards, Meenakshi Sundaram R |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3544 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
271浏览 2评论
170浏览 2评论
355浏览 2评论
297浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 10:31 , Processed in 0.415112 second(s), Total 42, Slave 37 queries .
