使用PSoC创建者4.1和CY84247模块在CyKIT-042上。我使用P3.5作为UART TX通过SCB1。所有的工作都很好,UART,但是我需要把TX线拉到1秒来重置CAMS,然后转向UART TX。如何将P3.5TX线重新配置为GPIO线,然后在运行时以编程方式返回到TX线?
谢谢 韦恩 以上来自于百度翻译 以下为原文 Using Psoc Creator 4.1 and CY84247 module on the CYKit-042. I am using P3.5 as uart tx via SCB1. Everything works fine w the UART, but I need to pull down the TX line for ~1sec to reset comms then turn back to UART TX. How do I reconfigure the P3.5 TX line as a GPIO line and then back to a TX line programmatically at runtime? Thanks Wayne |
3个回答
请参阅此线程:在运行时将SWD引脚更改为GPIO
但是,总结一下: “可以使用适当的PixStReDeVelDead()API在任何时候设置PIN的驱动模式。”@ USER13138899。 以上来自于百度翻译 以下为原文 See this thread: Change SWD pins to GPIO at runtime But, to summarize it here: "You may set the drive mode of a pin at any time using the appropriate Pin_SetDriveMode() API." @user_1377889 |
yuhe82 发表于 2018-11-21 10:33 谢谢,我不清楚如何处理我的问题。我读了UM RE PixStReDeValMeDe(),仍然不理解如何以实际的方式使用它。 Pi11yDm强驱动 Pix1MyOdOHYI开漏,驱动高 Low的开沟排水 Posi11DMSRESUPUP电阻拔出 Posi11MdReSydWNN电阻下拉 Posi11MdReSyxUPDN电阻拉/升 Pix1MyDig-Digi-Hiz高阻抗数字 Pij11MdAlGaZnHiZ高阻抗模拟 我假设Pix11dMyStand参数实际上是Pix5IsHistor,但是如何通过/选择端口?一旦更改为GPIO如何将端口/引脚返回到UART? 你能给出一个代码例子吗? -将P3.5设置为GPIO -驱动P3.5低 -等待1秒 -将P3.5设置为UART TX 谢谢你的帮助 以上来自于百度翻译 以下为原文 Thanks, the link was not clear to me how to address my issue. I read the UM re Pin_SetDriveMode() and still not understanding how to use this in a practical manner Pin_1_DM_STRONG Strong Drive Pin_1_DM_OD_HI Open Drain, Drives High Pin_1_DM_OD_LO Open Drain, Drives Low Pin_1_DM_RES_UP Resistive Pull Up Pin_1_DM_RES_DWN Resistive Pull Down Pin_1_DM_RES_UPDWN Resistive Pull Up/Down Pin_1_DM_DIG_HIZ High Impedance Digital Pin_1_DM_ALG_HIZ High Impedance Analog I assume the parameter PIN_1_DM_STRONG would actually be PIN_5_STRONG, but how do pass/select the port? Once changed to GPIO how to return the port/pin back to uart? Can you give a code example; -Set P3.5 to GPIO -Drive P3.5 low -Wait 1sec -Set P3.5 to UART TX Thanks for your help |
由于E.PrATT指向正确的方向,我发现了与我同样要求的重新配置线程。我能成功;
-将P3.5(Tx)设置为GPIO= //重置所需的位来制作GPIO,请注意将RX引脚更改为GPIO。 CyrgStIrgRe32(CyReGythHsiMouthPosier-Sel3,CythGETYRG32)(CyrGrGyHsiMouthPurtHel-Sel3)和0xFF0FFFF; /下一个设定的期望模式 UARTHTXXSEDRIVEVMODED(UARTHARTXXDMSYORM); -驱动器P3.5低= /按需要设置驱动器级别 UARTHARTXX写(0); -将P3.5设置为UART TX= //设置需要的比特来恢复GPIO返回UART //在GPIO改变之前,CyrGrxHsiMoxPurtHel-Sel3每单位容量为0x90099万h。 CyrGeStIrgRe32(CyReGythHsiMouthPurth-Sel3,CygGeTyGeR32(CyrgsiHsioMyPurth-SEL3)0x0.99万); 以上来自于百度翻译 以下为原文 Thanks to e.pratt pointing me in the right direction I found reconfigure thread that has the same requirement as myself. I'm able to successfully; -Set P3.5 (TX) to GPIO = //reset required bits to make GPIO, note this changes RX pin to GPIO as well CY_SET_REG32(CYREG_HSIOM_PORT_SEL3,CY_GET_REG32(CYREG_HSIOM_PORT_SEL3) & 0xFF00FFFF); //next set desired mode UART_tx_SetDriveMode(UART_tx_DM_STRONG); -Drive P3.5 low = //set drive level as desired UART_tx_Write(0); -Set P3.5 to UART TX = //set required bits to revert GPIO back to UART //prior to GPIO change CYREG_HSIOM_PORT_SEL3 was 0x00990000 per cyfitter.h CY_SET_REG32(CYREG_HSIOM_PORT_SEL3,CY_GET_REG32(CYREG_HSIOM_PORT_SEL3) | 0x00990000); |
754个成员聚集在这个小组
加入小组2111 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1792 浏览 6 评论
1540 浏览 1 评论
579浏览 2评论
432浏览 2评论
442浏览 2评论
391浏览 2评论
981浏览 2评论
GMT+8, 2024-12-29 14:47 , Processed in 0.737049 second(s), Total 47, Slave 42 queries .
