你好,
PWM分量,PWM分量的线输出被反转,PWM对齐是正确对齐的,我认为只有CC才输出低电平。 当PWM计数器在CC和UN(TC)之间时,API API TCPWMMSTEP()停止。如果组件重新启动,线路输出将高到下一个CC定时? 最好的问候,Inoue 以上来自于百度翻译 以下为原文 Hi, There is a PWM Component. The line output of PWM Component is inverted and PWM align is Right align. I think output is toggled Low only by CC. It stopped by API TCPWM_Stop() when PWM counter was between CC and UN(TC). If the component is restarted, the line output will be High until next CC timing? Best Regards, Inoue |
线路输出不在CC切换。有一个比较
行=比较值& lt;=计数器值。 鲍勃 以上来自于百度翻译 以下为原文 The line output is not toggled at cc. There is a comparision made as Line = Compare value <= Counter value. Bob |
760个成员聚集在这个小组
加入小组2155 浏览 1 评论
1903 浏览 1 评论
3725 浏览 1 评论
1836 浏览 6 评论
1581 浏览 1 评论
788浏览 2评论
546浏览 2评论
488浏览 2评论
447浏览 2评论
1224浏览 2评论
GMT+8, 2025-3-5 10:56 , Processed in 0.874465 second(s), Total 43, Slave 38 queries .
