你好,
对于我们的设计(ISE 10.1.03)中超过2 GB的RAM要求,我们需要将windows xp 32位更改为64位版本。 首先,我们成功安装了10.1.03。 但是在尝试安装10.1.03的IP更新时,我们遇到了一个错误: “无法安装此更新,因为一个或多个系统要求未得到满足: 所需产品:ISE 所需配置: 所需类型:具体 所需版本:10.1.03“ 我无法理解问题是什么?有人可以帮助我们吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, For RAM requirements more than 2 GB in our design (ISE 10.1.03), we need to change windows xp 32 bit to 64 bit version. First, we installed 10.1.03 successfully. But while trying install IP update of 10.1.03, we have encountered an error which is : "This update can not be installed, as one or more of the system requirements are not met: required product : ISE required configuration : required type :specific required version : 10.1.03 " I can't understand what the problem is? Can anyone please help us? Thanks. |
5个回答
http://www.xilinx.com/support/download/index.htm
查看版本“10.1 SP3”。 32位和64位窗口都有单独的安装程序。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 http://www.xilinx.com/support/download/index.htm Check out version "10.1 SP3". There're separate installers for 32-bit and 64-bit windows. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
您是否为64位窗口应用了SP3?
32位和64位窗口有单独的Service Pack安装文件。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Have you applied SP3 for 64-bit windows? There're separate service pack installation files for 32-bit and 64-bit windows. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
windows xp 64bit没有sp3。
32位只有sp3。 我们在计算机上安装了sp2。 以上来自于谷歌翻译 以下为原文 There is no sp3 for windows xp 64bit. There is only sp3 for 32 bit. We have sp2 installed in our computer. |
查看版本“10.1 SP3”。 32位和64位窗口都有单独的安装程序。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 http://www.xilinx.com/support/download/index.htm Check out version "10.1 SP3". There're separate installers for 32-bit and 64-bit windows. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
非常感谢你。
我们已经成功安装了10.1.03更新和ip update.But现在当我们在旧项目上运行ise(新创建的项目但是有旧的vhdl和coregen文件)时,我们在综合中遇到错误报告:Error signatureEventType: BEX64 P1:xst.exe。 P2:0.0.0.0。 P3:48bda5b0 P4:libXst_Flow.dll。 P5:0.0.0.0。 P6:48ac842e。 P7:0000000000079ddc。 P8:c0000409。 P9:0000000000000000这是什么原因? 以上来自于谷歌翻译 以下为原文 Thank you very much. We have successfully installed 10.1.03 update and also ip update. But now when we make ise run on our old project (newly created project but has old vhdl and coregen files), we encounter an error report in synthesis which is : Error signature EventType: BEX64 P1:xst.exe. P2:0.0.0.0. P3:48bda5b0 P4:libXst_Flow.dll. P5:0.0.0.0. P6:48ac842e. P7:0000000000079ddc. P8:c0000409. P9:0000000000000000 What is the reason for this? |
2363 浏览 7 评论
2782 浏览 4 评论
2247 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
730浏览 1评论
524浏览 1评论
336浏览 1评论
742浏览 0评论
1940浏览 0评论
GMT+8, 2024-11-10 13:43 , Processed in 1.136089 second(s), Total 53, Slave 48 queries .
