嗨,
我刚刚在Windows XP Pro SP3上安装了Xilinx 12.2(webpack),当我尝试启动Project Navigator时,收到了这个错误: 未找到ISE功能的许可证。 导致此错误的典型原因是找不到许可证文件或找到的许可证文件不包含具有所需功能的未过期许可证。 将启动Xilinx许可证配置管理器(XLCM)以帮助您查找或获取许可证文件。 当我安装程序时,我安装了收到的许可证文件。 我使用Users组的用户成员来执行该程序,但我以管理员身份运行它。 这是我的许可证文件的内容: #-----移除此处的线路-------------------------- ##此许可证有效期自Sun Sep 26 18:27: 00 GMT + 00:00 2010。##这是NODELOCKED到HOStiD = ANY的许可证;#不需要为此许可证运行lmgrd。###这是在Sun Sep 26 18:27:00 GMT生成的永久许可证 +00:00 2010INCREMENT Web_Package xilinxd 2011.09永久不计数 B57B884B56FD VENDOR_STRING =电子邮件@ domain.com,Web_Package,软件,永久,_180519792_0_0_210 HOSTID =任何问题=“Xilinx Inc”START = 26-Sep-2010 TS_OK ### - -------------------------------------------------- -------------------#以下PACKAGE定义是此许可证的必需部分:#PACKAGE Web_Package xilinxd 2011.09 5CD007FCE0EE COMPONENTS =“PlanAhead WebPACK”OPTIONS = SUITE ## -------------------------------------------------- ---------------------------- ## -----在这下面删除线路----------- --------------- 任何帮助将非常感谢。 以上来自于谷歌翻译 以下为原文 Hi, I just installed Xilinx 12.2 (webpack) on a Windows XP Pro SP3 and when I try to start Project Navigator, I received this error: A license was not found for the ISE feature. Typical causes for this error are either that there is no license file found or that license files, which were found, do not contain an unexpired license with the required feature. The Xilinx License Configuration manager (XLCM) will be launched to assist you with locating or obtaining a license file. When I installed the program, I installed the license file I received. I lauch the program with a user member of the Users group but I run it as administrator. Here's the content of my license file: # ----- REMOVE LINES ABOVE HERE -------------------------- # # This license is valid from Sun Sep 26 18:27:00 GMT+00:00 2010. # # This is license NODELOCKED to HOSTID=ANY; # there is no need to run lmgrd for this license. # # # This is a permanent license generated on Sun Sep 26 18:27:00 GMT+00:00 2010 INCREMENT Web_Package xilinxd 2011.09 permanent uncounted B57B884B56FD VENDOR_STRING=email@domain.com,Web_Package,software,permanent,_180519792_0_0_210 HOSTID=ANY ISSUER="Xilinx Inc" START=26-Sep-2010 TS_OK # # # ---------------------------------------------------------------------- # The following PACKAGE definition is a REQUIRED part of this license: # PACKAGE Web_Package xilinxd 2011.09 5CD007FCE0EE COMPONENTS="PlanAhead WebPACK" OPTIONS=SUITE # # ------------------------------------------------------------------------------ # # ----- REMOVE LINES BELOW HERE -------------------------- Any help will be very appreciated. |
9个回答
嗨,
在我的上一篇文章和你的答案之间,我发现了它。 我可以按照您说的方式执行此操作,或者只需添加以下注册表项: HKEY_CURRENT_USER 环境 有了这个值: XILINXD_LICENSE_FILE = C: XILINX 谢谢你的帮助。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, Between my pervious post and your answer, I found it. I can do it the the way you said or just add the following registry key: HKEY_CURRENT_USEREnvironment With this value: XILINXD_LICENSE_FILE=C:.XILINX Thanks for your help. View solution in original post |
当我在管理员会话上运行该软件时,我没有收到任何许可证错误。
以上来自于谷歌翻译 以下为原文 When I run the software on the administrator session, I don't receive any license error. |
您是否根据您的登录方式改变了位置?
该软件将默认在%HOMEDRIVE%。Xilinx上查找许可证。 您可以尝试的另一件事是将XILINXD_LICENSE_FILE变量指向许可证文件,即使它位于默认目录中。 例如XILINXD_LICENSE_FILE = c:。Xilinx Webpack.lic 以上来自于谷歌翻译 以下为原文 Does you HOMEDRIVE location change depending on how you log in? The software will look for the license at %HOMEDRIVE%.Xilinx by default. Another thing you could try is to point the XILINXD_LICENSE_FILE variable to the license file even if it is in the default directory. e.g XILINXD_LICENSE_FILE=c:.XilinxWebpack.lic |
嗨howardp,
HOMEDRIVE是什么意思? 是用户档案吗? 我认为许可证已复制到C:。Xilinx。 我在哪里可以更改许可证的默认路径变量? 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi howardp, What do you mean by HOMEDRIVE ? Is it the user profile ? I thought that the license was copied to C:.Xilinx. Where can I change the default path variable for the license ? Thanks for your help. |
HOMEDRIVE是一个系统环境变量。
通常它设置为C: 许可证文件被复制到%HOMEDRIVE% .Xilinx,通常是C:。Xilinx。 如果HOMEDRIVE变量对于管理员设置为C:,对于用户设置为H:,则许可文件的复制位置与软件查找位置之间可能不匹配。 在任何情况下,将XILINXD_LICENSE_FILE变量设置为指向文件的实际位置都可以解决问题。 有关检查和设置环境变量的信息,请访问http://www.xilinx.com/support/answers/11630.htm。 以上来自于谷歌翻译 以下为原文 HOMEDRIVE is a system environment variable. Typically it is set to C: The license file is copied to %HOMEDRIVE%.Xilinx which is usually C:.Xilinx. If the HOMEDRIVE variable is set to C: for the administrator and H: for the user, there could be a mismatch between where the license file gets copied and where the software looks for it. In any case, setting the XILINXD_LICENSE_FILE variable to point to the actual location of the file would resolve the problem. See http://www.xilinx.com/support/answers/11630.htm for checking and setting environment variables. |
嗨,
很抱歉回到论坛上的时间。 %HOMEDRIVE%变量设置为网络上的用户配置文件位置。 我是否可以在不更改%HOMEDRIVE%变量的情况下设置Xilinx许可证文件位置? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, Sorry for the time it takes to come back on the forum. The %HOMEDRIVE% variable is set to the user profile location on the network. Can I set the Xilinx license file location without changing the %HOMEDRIVE% variable ? Thanks. |
嗨,
如果我再次以用户身份安装许可证,则会将许可证文件复制到%HOMEDRIVE .Xilinx文件中,但在启动Xilinx Project导航器时仍然会出现错误。 如何设置XILINXD_LICENSE_FILE变量? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, If I installed the license again as a user, it copy the license file to the %HOMEDRIVE.Xilinx file but I still get the error when I launch Xilinx Project navigator. How can I set the XILINXD_LICENSE_FILE variable ? Thanks. |
用于检查和设置环境变量。 例如,要在Windows XP Professional上全局设置变量,请执行以下操作: 1。 右键单击“我的电脑”,然后选择“属性”。 (注意:“我的 如果计算机“不在”“开始”菜单下,它将位于“开始”菜单下 桌面。) 2.单击“高级”选项卡。 3.单击“环境” 变量,并添加所需的变量。 变量:XILINXD_LICENSE_FILE 价值:H:。Xilinx 使用许可证文件的目录位置作为值。 以上来自于谷歌翻译 以下为原文 See http://www.xilinx.com/support/answers/11630.htm for checking and setting environment variables. For Example, to globally set the variable on Windows XP Professional do the following: 1. Right-click My Computer, and select Properties. (NOTE: "My Computer" will be located under the "Start" menu if it is not on the desktop.) 2. Click the Advanced tab. 3. Click Environment Variables, and add the desired variable. Variable: XILINXD_LICENSE_FILE Value: H:.Xilinx Use the directory location of the license file for the value. |
嗨,
在我的上一篇文章和你的答案之间,我发现了它。 我可以按照您说的方式执行此操作,或者只需添加以下注册表项: HKEY_CURRENT_USER 环境 有了这个值: XILINXD_LICENSE_FILE = C: XILINX 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi, Between my pervious post and your answer, I found it. I can do it the the way you said or just add the following registry key: HKEY_CURRENT_USEREnvironment With this value: XILINXD_LICENSE_FILE=C:.XILINX Thanks for your help. |
2601 浏览 7 评论
2923 浏览 4 评论
2376 浏览 9 评论
3477 浏览 0 评论
2554 浏览 15 评论
3108浏览 1评论
723浏览 1评论
599浏览 1评论
GMT+8, 2025-4-21 01:19 , Processed in 1.601390 second(s), Total 94, Slave 76 queries .
