大家早上好,
我最近为我的新装备购买了i7-7820x处理器和X299 Gaming M7 ACK主板。 经过进一步的研究(我本来应该做的更多)。 我发现i7-8086k的游戏基准测试增加了约4%。 我不确定它是否值得将我的电脑分开,所以我可以将处理器和主板重新交换,或者它甚至不值得。 我知道7820的功率更高,所以我希望这也不是问题。 前几天我的电脑游戏大约是48-55c。 任何帮助或建议将不胜感激。 谢谢。 -Derek 以上来自于谷歌翻译 以下为原文 Good Morning All, I have recently purchased a i7-7820x processor and a X299 Gaming M7 ACK motherboard for my new rig. Upon further research (which I should have done more of to begin with). I found out that the i7-8086k has about a 4% increase on the bench mark for gaming. I'm not sure if its worth tearing my computer apart so I can take the processor and motherboard back to exchange is or if its not even worth it. I know the 7820 runs at a higher wattage so I'm hoping that is not an issue as well. My pc gaming the other day was running around 48-55c. Any help or advice would be greatly appreciated. Thank you. -Derek |
你可以在这里比较两个处理器:
英特尔®产品规格比较 在您执行任何操作之前,请确保主板BIOS支持i7-8086k,并且兼容插槽。 文件 以上来自于谷歌翻译 以下为原文 You can compare the two processors here: Intel® Product Specification Comparison Before you do anything, make sure the i7-8086k is supported by the motherboard bios, and is socket compatible. Doc |
562浏览 0评论
GMT+8, 2025-2-3 14:25 , Processed in 0.513764 second(s), Total 47, Slave 41 queries .
