虽然STM8参考手册RM0031似乎没有提到它,但我从AN2658(第2.7节)了解到我必须按特定顺序读取ADC_DRH和ADC_DRL,实际的顺序取决于我的ADC配置。
似乎很明显(至少对我来说)LDW指令可用于读取这两个连续位置是一条指令。 AN2658没有提到这种“明显”的方法,所以我在理解中遗漏了一些东西。 LDW在这种淤积中不安全吗? 具体来说,我的意图是做到: LDW x,$ 0x5344 要么 LDW y,$ 0x5344 ♯ ‌♯ ♯ “ https://community.st.com/tags♯/?tags=16-bit%20adc htthttps://community.st.com/tags♯/?tags=adc%20stm8 #adc #atomic #ldw#16-bit-adc#adc-stm8 以上来自于谷歌翻译 以下为原文 Although the STM8 reference manual RM0031 does not seem to mention it, I understand from the AN2658 (section 2.7) that I must read ADC_DRH and ADC_DRL in a specific order, with the actual order depending on my configuration of the ADC. It seems obvious (at least to me) that the the LDW instruction can be use to read these two consecutive locations is one instruction. AN2658 does not mention this 'obvious' method, so I'm I missing something in my understanding. Is LDW unsafe in this siltation? Specifically I was intent is to do either: LDW x, $0x5344 or LDW y, $0x5344 ♯ ‌♯ ♯ ‌ https://community.st.com/tags♯/?tags=16-bit%20adc ‌ https://community.st.com/tags♯/?tags=adc%20stm8 #adc #atomic #ldw #16-bit-adc #adc-stm8 |
ldw在两个周期内执行,AFAIK始终首先读/写最低有效字节。所以如果你可以使用ldw也取决于配置。
菲利普 以上来自于谷歌翻译 以下为原文 ldw executes in two cycles and AFAIK always reads/writes the least significant byte first. So if you can use ldw also depends on the configuration. Philipp |
2783 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1349浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-13 16:38 , Processed in 1.133761 second(s), Total 76, Slave 60 queries .
