扫一扫,分享给好友
我们在Flasher中使用LED6001 LED驱动器。
问题是当输入小于10.5V时,它工作在O.K但是当输入大于10.5V时,LED电流降低到接近10mA或关闭。问题与O / P的6LED和O / P的12LED相同。我们也尝试将OVP远远超过O / P所需的挥发量,但仍然存在这个问题。 请帮我们解决问题。 请找到更新的原理图。 #boost-led-driver#led6001 #led-driver 以上来自于谷歌翻译 以下为原文 We are using LED6001 LED Driver in a Flasher. The problem is when the input is less than 10.5V it works O.K but when the input is more than 10.5V the LED current reduces to almost 10mA or shuts down. The Problem is same with 6LEDs at the O/P and 12LEDs at the O/P. We have also tried shifting the OVP much above the O/P required volatage, but still this problem exists. Please help us to resolve the problem. Please find the updated schematic. #boost-led-driver #led6001 #led-driver |
我认为问题在于输入电流检测和COMP R-C值,任何人都可以帮我解决它。
以上来自于谷歌翻译 以下为原文 I think the problem is with Input current sensing and COMP R-C values, could anyone help me to sort out it. |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 13:07 , Processed in 1.028060 second(s), Total 77, Slave 61 queries .
