从16754A LA板更换FPGA芯片散热器有什么困难吗?我已经(重新)应用了几次导热膏和散热器用于普通GPU和CPU但是我想知道这些FPGA散热器的外部/边缘粘贴是否有些
特殊胶水膏。 以上来自于谷歌翻译 以下为原文 Are there any difficulties to replacing a FPGA chip heatsink from the 16754A LA board? I have (re)applied several times the thermal paste and the heatsinks for normal GPUs and CPUs but I was wondering if the outer/edge paste for these FPGA heatsinks is some special glue paste. |
3个回答
我会检查,但是这些信息可能会在时间的迷雾中消失。该卡在2005年的某个时候停止使用,并在2010年8月“失去支持”。安捷伦的制造业在此期间已经开始转移,因此追逐旧的制造流程
可能不可能.Al 以上来自于谷歌翻译 以下为原文 I'll check, but that information may be lost in the mists of time. That card was discontinued sometime in 2005, and went 'Out of Support' in August 2010. Agilent's manufacturing has moved in the meantime, so chasing down old manufacturing processes may not be possible. Al |
nvywyerwer 发表于 2018-11-20 07:38 不幸的是,当一个散热器与插槽A的上边缘缠绕在一起时,有一个散热片从板上掉下来(有一些金属线干扰了散热器结构)。 以上来自于谷歌翻译 以下为原文 Unfortunately, one heatsink fell off the board when I had to apply force after it was entangled with the upper edge of the slot A (there are some metal threads that interfered with the heatsink structure). |
我已经能够使用芯片上的MX-4和散热器外边缘上的Arctic Alumina Thermal Adhesive重新连接散热器。 唯一的缺点是这个程序非常永久地粘合散热器的压力因此需要避免任何错误。 以上来自于谷歌翻译 以下为原文 I have been able to reattach the heatsink using MX-4 on the chip and Arctic Alumina Thermal Adhesive on the outer margins of the heatsink. The only downside is the stress that this procedure glues the heatsink quite permanently hence the need to avoid any mistakes while doing it. |
1032 浏览 0 评论
2277 浏览 1 评论
2064 浏览 1 评论
1936 浏览 5 评论
2807 浏览 3 评论
798浏览 1评论
584浏览 0评论
680浏览 0评论
2463浏览 0评论
1520浏览 0评论
GMT+8, 2024-9-20 20:32 , Processed in 1.571063 second(s), Total 79, Slave 63 queries .
