如何在PSoC6中使用UDB资源?
在PSoC Calor 4.2中,我找不到像PWM /UART等的UDB基础组件。 以上来自于百度翻译 以下为原文 How to use UDB resource in PSoC6? I cannot find UDB base component like PWM/UART, etc. in PSoC Creator4.2. |
7个回答
嗨,瑞,
PSoC 6的UDB与我们的P5LP族具有相同的体系结构, 但是基于UDB的组件,如PWM /UART可能在PSoC Creator 4.2的当前beta版本中还不可用。 谢谢。 以上来自于百度翻译 以下为原文 Hi Ray, The UDBs for PSoC 6 have the same architecture as our P5LP families, but the UDB based component like PWM/UART may not be available in current beta version of PSoC Creator 4.2 yet. Thanks. |
你好,
最新的PSoC创建者beta版可在这里:PSoC Creator 4.2贝塔2公告!附带许多UDB逻辑、寄存器和实用函数。基于UDB的组件,如PWM和UART将在下一次更新中添加。但是,我建议使用这些组件的固定函数等效项,即PWM(TCPWM)和UART(SCB),它们已经可用。除了使用PDL支持使代码模块化,这些固定功能块提供更好的功率效率。 如果你有任何其他问题,请告诉我。 当做 尼丁 以上来自于百度翻译 以下为原文 Hello, Latest PSoC Creator beta version available here: PSoC Creator 4.2 Beta 2 Announcement! comes with many UDB logic, registers, and utility functions. UDB based components such as PWM and UART will be added in the next update. However, I'd recommend using the fixed function equivalents of these components, namely PWM (TCPWM) and UART(SCB), which are already available. These fixed function blocks provide better power efficiency in addition to making your code modular with PDL support. Please let me know if you have any additional questions Regards Nidhin |
60user48 发表于 2018-11-20 15:01 Nidhin 谢谢你的回复。 我们可以使用UDB来驱动英特尔8080接口TFT吗?或者你有一个计划,通过UDB在PSoC5LP中实现EMIF功能的组件? 瑞 以上来自于百度翻译 以下为原文 Nidhin, Thank you for your reply. Can we use UDB to drive Intel 8080 interface TFT? Or do you have a plan to make a component to implement EMIF Function in PSOC5LP by UDB? ~Ray |
lxmlau 发表于 2018-11-20 15:18 嗨,瑞, 是的,我们有一个基于PSoC 6 UDB的并行TFT接口组件。使用该组件的几个代码示例和具有8位并行TFT的屏蔽将作为新QPSO 6套件的一部分被释放,其预定于Q1早期。请让我知道,如果你想看看目前正在进行的工作的代码示例。 当做 尼丁 以上来自于百度翻译 以下为原文 Hi Ray, Yes, we do have a PSoC 6 UDB based component for parallel TFT interface in the works. Several code examples using this component, and a shield with 8-bit parallel TFT will be released as a part of a new PSoC 6 kit scheduled for early Q1. Please let me know if you want to take a look at the code example that is a work in progress at the moment. Regards Nidhin |
60user48 发表于 2018-11-20 15:34 Nidhin 它应该很棒!请发送代码示例给我学习。非常感谢! BTW,关于帧缓冲RAM的扩展计划有哪些?UDB也能做到这一点吗?但它似乎需要内存映射。 使用QSPI接口扩展QSPI PSRAM的想法是什么? 当做, 射线 以上来自于百度翻译 以下为原文 Nidhin, It shoulds great! Please send the code example to me to study. Thank you very much! Btw, any plan about Frame buffer RAM extend? Can UDB do this also? But it seems need memory mapping. What about the idea to used QSPI interface to extend QSPI PSRAM? Regards, Ray |
lxmlau 发表于 2018-11-20 15:44 嗨,瑞, 请检查您的电子邮件的代码示例请注意,这是一个正在进行中的工作。 当做, 维萨克 以上来自于百度翻译 以下为原文 Hi Ray, Please check your email for the code example Please note that this is a work in progress. Regards, Vaisakh |
嗨,维萨克 请将8080接口的TFT代码发送到我的电子邮件中,非常感谢。 以上来自于百度翻译 以下为原文 Hi Vaisakh would you please send TFT code with 8080 interface to my email?many thanks。 |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 18:38 , Processed in 0.759401 second(s), Total 55, Slave 50 queries .
