扫一扫,分享给好友
我收到这条消息:
“安装过程中遇到以下错误: 11:无法找到存档按重试再试一次,否则按取消退出安装“ 操作系统:windows xp professionalsp2 取消安装后,似乎ise正在工作,我甚至更新了软件 但我怎么知道是否缺少某些东西? 谢谢 以上来自于谷歌翻译 以下为原文 i got this message: "the following erro was encountered during installation: 11: archive could not be located press retry to try again, otherwise press cancel to exit the installation" OS : windows xp professional sp2 after cancelling the installation it seems that ise is working and i even updated the software but how can i know if somthing is missing? thanks |
3个回答
错误发生在什么时候?
我不知道如何检查你是否遗漏了一些东西,除了将文件和文件夹与已知的工作安装进行比较,或者只是等到某些东西不起作用。 如果在安装过程中出现错误并且您点击取消而不是重试,则不应期望安装正常。 只是为了确保您应该卸载或删除发生错误的安装并重新安装。 大卫 以上来自于谷歌翻译 以下为原文 At what point did the error occur? I'm not sure how you can check if you are missing something except either comparing the files and folders to a known working installation or just waiting until something doesn't work. You shouldn't expect the install to be alright if it gave an error during installation and you hit cancel instead of retry. Just to be sure you should uninstall or delete the install where the error occurred and re-install. David |
首先,谢谢
当错误发生时留下深刻的印象,但它没有任何帮助,所以我按下取消。 现在关于chipcope如何安装一些插件? 谢谢 以上来自于谷歌翻译 以下为原文 first thanks when the error occur i pressed the retry but it didnt helped in any way so i pressed cancel. now about the chipscope how can i install some plugins ? thanks |
嗨Efis,
我不确定您对ChipScope插件的意思,因为您已经安装了更新。 你能说清楚你指的是什么吗? 大卫 以上来自于谷歌翻译 以下为原文 Hi Efis, I'm not sure what you mean by plugins for ChipScope as you've already installed the updates. Can you clarify what you are referring to? David |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
200浏览 1评论
652浏览 0评论
GMT+8, 2024-9-20 18:38 , Processed in 1.254493 second(s), Total 50, Slave 44 queries .
