嗨,
我正在尝试使用勤奋的USB-JTAG编程电缆将XC5VLX110T连接到我的桌面(运行CentOS-5的64位机器)。 但在ISE(11.1)iMPACT的状态栏中,我看到“没有电缆连接”。 当我尝试“有线自动连接”时,我得到iMPACT:923警告 - 找不到电缆。 我还从http://www.xilinx.com/support/documentation/configuration_hardware.htm安装了驱动程序。 如果有人能为此提供解决方案,那就太好了。 谢谢, 湿婆 以上来自于谷歌翻译 以下为原文 Hi, I am trying to connect the XC5VLX110T to my desktop (64-bit machine running CentOS-5) with a diligent USB-JTAG programming cable. But in ISE (11.1) iMPACT's status bar, I see "no cable connection". When i tried "cable auto connect", I get iMPACT:923 warning - can not find cable. I have also installed the drivers from http://www.xilinx.com/support/documentation/configuration_hardware.htm. It will be great if anyone can provide a solution for this. Thanks, Siva |
你好:
Digilent USB-JTAG需要自己的驱动程序和digilent提供的软件。 下载熟练的套件,只需加载由ISE和程序生成的配置文件,所以只需将进程运行到生成配置文件即可。 http://www.digilentinc.com/Products/Detail.cfm?NavTop=2&NavSub=69&Prod=ADEPT 有链接,64和32位窗口的版本可用。 以上来自于谷歌翻译 以下为原文 Hi: The Digilent USB-JTAG needs its own drivers and software provided by digilent. Download the adept suite, there you just load the Configuration File generated by ISE and program, so just run the processes up to Generate Configuration File and you're done. http://www.digilentinc.com/Products/Detail.cfm?NavTop=2&NavSub=69&Prod=ADEPT There's the link, versions for 64 and 32 bit windows are available. |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
734浏览 1评论
524浏览 1评论
337浏览 1评论
742浏览 0评论
1940浏览 0评论
GMT+8, 2024-11-10 14:28 , Processed in 0.946076 second(s), Total 45, Slave 40 queries .
