4个回答
我不知道任何看门狗单独供电的MCU。
有两种可能性: 你正在阅读标准错误。要么 他们有一个独立的看门狗电路。 以上来自于谷歌翻译 以下为原文 I'm not aware of any mcu whose watchdog is separately powered. So two possibilities: 1. You are reading the standard wrong. Or 2. They have a separate watchdog circuitry. |
这是我对此的看法。
1.监控设备需要有自己的时间基础 - 对于典型的mcu来说并不困难; 2.监控设备需要独立供电 - 我从未见过这种类型的供电方案; 3.监控设备通常是外部的,但不是所有的方式 - 它确实为车载看门狗提供了一些余地,但考虑到2),没有太大的余地。 将它们放在一起,我认为几乎不可能在mcu中使用看门狗,它也在执行数字处理以执行监控。如果一个mcu确实用于此目的,它要么具有奇怪/不寻常的看门狗电源域,要么有问题。 以上来自于谷歌翻译 以下为原文 here is my take on that. 1. the monitoring equipment needs to have its own time base - not difficult for a typical mcu; 2. the monitoring equipment needs to be independently powered - i have never seen this type of powering scheme; 3. the monitoring equipment is generally external but not all ways - it does provide some leeway for an onboard watchdog but given 2) above, not much leeway. put that together, I think it is next to impossible to use the watchdog inside of a mcu that's also performing the digital processing to perform the monitoring. if a mcu is indeed used for this purpose, it either has a weird / unusual watchdog power domain, or questionable compliance. |
2821 浏览 1 评论
3262 浏览 1 评论
1838 浏览 1 评论
3687 浏览 6 评论
6091 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
390浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
480浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
309浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
227浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
332浏览 2评论
GMT+8, 2025-1-31 17:44 , Processed in 0.915941 second(s), Total 49, Slave 43 queries .
