嗨,我怀疑这个模块是在新的PIC32 MK上实现的吗?文档和勘误表是空的。有任何指示I2C1,I2C…与引脚有关。我已经测试(“手动”)所有四个通道上的E12和E13(PIC32 1024MCF064)没有任何影响。只有I2C4,SDA始终是Low和SCL高。有人已经在PIC32 MK上实现这个模块(甚至使用和声,PLIB不工作)?似乎只有一种方法是使用SW解决方案?我需要I2C来配置一些组件。谢谢你的帮助。
以上来自于百度翻译 以下为原文 Hi, I've large doubts if this module is implemented on the new PIC32MK? Documentation and Errata are empty. There any indication for I2C1, I2C ..... related to pins. I've tested ("manually") all four channel on the E12 and E13 (PIC321024MCF064) without any effects. Only for I2C4 the SDA is always Low and SCL High. Someone has already implemented this module (even using HARMony, plib doesn't work) on the PIC32MK? It seems that only one way is to use the SW solution ? I need I2C to configure some components. Thanks for help. |
复制:HTTP://www. MigCHIP.COM/FUMMS/M10333.6ASPX。自上次以来,答案没有改变,PIC32 MK没有I2C外围设备。
以上来自于百度翻译 以下为原文 Duplicate: http://www.microchip.com/forums/m1034326.aspx The answer hasn't changed since the last time, the PIC32MK does not have an I2C peripheral. |
最后,应用调试和示波器,发现引脚E12和E13由I2C4控制,并开始工作。我将在这个周末准备一个小例子,并把它添加到“我的”自己的云中。
以上来自于百度翻译 以下为原文 Finally, applying Debug and oscilloscope I found that pins E12 and E13 are controlled by I2C4 and it starts to work. I will prepare this week-end a small examples and add it on "my" Own Cloud. https://electronics-lis.com/OwnClouds/index.php/s/DgmcLyL4l43HSBx pwd: toto |
5323 浏览 9 评论
2076 浏览 8 评论
1982 浏览 10 评论
3254 浏览 3 评论
2293 浏览 5 评论
835浏览 1评论
730浏览 1评论
674浏览 1评论
728浏览 0评论
622浏览 0评论
GMT+8, 2025-2-3 09:56 , Processed in 0.947275 second(s), Total 46, Slave 40 queries .
