嗨,我正在通过英特尔网络浏览英特尔NUC 7i5BNH的规格,我看到该系统与以下Optane内存兼容:
Intel16GB M.2 PCIe NVMe内存MICPEK1W016GA 英特尔验证 然而,在通过商店导航找到这样的内存后,我被提供了下一级的Optane内存,即32 Gb。 英特尔Optane内存模块32 GB PCIe M.2 80mm MEMPEK1W032GAXT 我想知道这个32GB Optane内存模块是否可以与7i5BNH兼容? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I was surfing through the Intel Web for the specs of the Intel NUC 7i5BNH, and I saw that the system is compatible with the following Optane memory:
However, after navigatiing through a store to find such memory, I was being offered the next level of Optane memory which is 32 Gb. Intel Optane Memory Module 32 GB PCIe M.2 80mm MEMPEK1W032GAXT I was wondering if this 32GB Optane memory module could be compatible with the 7i5BNH? Thanks. |
3个回答
是的,你当然可以 - 事实上,为了加速更大尺寸的硬盘驱动器,这个32GB版本可以(最终)提高性能(即更多空间用于缓存更多文件)。
小心,市场上有更大的(64GB +)模块,但这些模块有不同的用途。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 Yes, you certainly can - and, in fact, for accelerating larger-sized HDDs, this 32GB version can (eventually) improve performance even more (i.e. more space for caching more files). Be careful, there are even larger (64GB+) modules on the market, but these modules have a different purpose. Hope this helps, ...S |
您好allGreetings,我想与您分享我使用英特尔®NUC套件NUC7i7BNH(https://ark.intel.com/products/95065/Intel-NUC-Kit-NUC7i7BNH)快速完成了我的工作
使用英特尔®Optane™内存系列(https://ark.intel.com/products/99742/Intel-Optane-Memory-Series-32GB-M_2-80mm-PCIe-3_0-20nm-3D-Xpoint?q=mempek1w032ga) 和Windows®1064位,我能够设置系统没有问题。 请让我知道您的英特尔®NUC上安装的BIOS版本。希望此帮助。 此致,莱昂纳多C. 以上来自于谷歌翻译 以下为原文 Hello all Greetings, I would like to share with you that I have done a quick lap on my side with an Intel® NUC Kit NUC7i7BNH (https://ark.intel.com/products/95065/Intel-NUC-Kit-NUC7i7BNH) using Intel® Optane™ Memory Series (https://ark.intel.com/products/99742/Intel-Optane-Memory-Series-32GB-M_2-80mm-PCIe-3_0-20nm-3D-Xpoint?q=mempek1w032ga) and Windows® 10 64 bit and I was able to set the system with no problem. Please let me know the BIOS version installed on your Intel® NUC. Hope this help. Regards, Leonardo C. |
你好allI正在检查你的情况,想知道你是否需要进一步的帮助。
如果是这样,请不要犹豫回复.Regards,Leonardo C. 以上来自于谷歌翻译 以下为原文 Hello all I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back. Regards, Leonardo C. |
GMT+8, 2025-7-12 19:07 , Processed in 0.751262 second(s), Total 79, Slave 63 queries .
