void enter_standby_mode(void)
{ //IO口配置 GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//_IPD输入上拉 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//_IPD输入下拉 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//_IPD输入上拉 GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin=(GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//_IPD输入下拉 GPIO_Init(GPIOA, &GPIO_InitStructure);//配置A口 其中9 10 为串口,13 14为TMS TCK,共16口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//_IPD输入上拉 GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//下拉 GPIO_Init(GPIOB, &GPIO_InitStructure);//配置B口 共16口 GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//下拉 GPIO_Init(GPIOC, &GPIO_InitStructure);//端口C的配置,共16个端口 GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_2); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//下拉 GPIO_Init(GPIOD, &GPIO_InitStructure);//端口D的配置,1个端口 //一共64端口。ABCD配置了49个端口,VBAT VDD VSS等11个电源端口不用配置 49+11=60 //没有配置的端口有复位端口NRST、boot0端口、PD0(OSC_IN)、PD1(OSC_OUT)等4个端口 RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); //使能PWR外设时钟 PWR_EnterSTANDBYMode(); //进入待命(STANDBY)模式 } 在成功设置低功耗模式后,需要周期性的运行程序,然后进入低功耗,间隔意见时间后,继续运行程序。这时就需要用到RTC时钟来进行对低功耗模式的唤醒。低功耗的stop模式,需要配置EXTI_line17来设置唤醒闹钟,然后才能唤醒stop模式。standby模式不需要设置EXTI_line17,可以直接通过void RTC_IRQHandler(void)中断函数实现唤醒,在配置好RTC的情况下,只需要在主函数加入下列程序即可。 void huanxing(void) { RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR|RCC_APB1Periph_BKP, ENABLE); PWR_BackupAccessCmd(ENABLE); RTC_SetAlarm(RTC_GetCounter()+50); RTC_WaitForLastTask(); RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); PWR_WakeUpPinCmd(ENABLE); PWR_EnterSTANDBYMode(); } 网上找的F103的,你的代码是什么
最佳答案
2373 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1257 浏览 0 评论
3206 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2977 浏览 4 评论
5546 浏览 0 评论
GMT+8, 2025-1-23 11:27 , Processed in 0.374125 second(s), Total 41, Slave 36 queries .
