我们目前在计算机上安装了Xilinx ISE 10.1,但我们需要CORDIC v4.0,它是新型Xilinx ISE 11.1的一部分。
是否可以从Xilinx ISE 10.1升级到Xilinx ISE 11.1而无需付费? 此外,是否可以安装带有Xilinx ISE 10.1的11.1版Core Generator? 以上来自于谷歌翻译 以下为原文 We currently have Xilinx ISE 10.1 installed on our computer, but we need CORDIC v4.0 which is part of the newer Xilinx ISE 11.1. Is it possible to upgrade from Xilinx ISE 10.1 to Xilinx ISE 11.1 without having to pay? Also, is it possible to install version 11.1 of Core Generator with Xilinx ISE 10.1? |
3个回答
根据您购买10.1的时间,我认为这是可能的。
尝试联系Xilinx的客户服务小组。 如果不安装相应的ISE工具,则无法安装CoreGen。 以上来自于谷歌翻译 以下为原文 Depending on when you purchased 10.1, I would assume this is possible. Try contacting Xilinx's Customer Service group. You can't install just CoreGen without installing it's corresponding ISE tools. |
如quiksuuver建议,请联系客户服务部cs_1@xilinx.com,了解ISE DS 11.1发布后您是否仍在保修期内,以及您是否有权使用ISE DS 11.1。
CoreGen是ISE设计套件的一部分。 要安装CoreGen,需要安装ISE DS。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 As quiksuuver suggests, contact Customer Services at cs_1@xilinx.com to see if you were still in warranty when ISE DS 11.1 was released and if you are entitled to ISE DS 11.1. CoreGen is part of the ISE Design Suite. To install CoreGen, ISE DS needs to be installed. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2539 浏览 7 评论
2892 浏览 4 评论
2345 浏览 9 评论
3443 浏览 0 评论
2527 浏览 15 评论
2776浏览 1评论
683浏览 1评论
545浏览 1评论
838浏览 0评论
GMT+8, 2025-3-19 17:02 , Processed in 1.665879 second(s), Total 79, Slave 63 queries .
