“未设置环境变量。需要安装ise工具的comptabile verision来运行xps
按Enter键关闭“ 我使用ise12.1套件,当我打开xps时,我该怎么做才能解决问题? 以上来自于谷歌翻译 以下为原文 "Environment variable is not set. A comptabile verision of ise tools needs to be installed to run the xps press enter to close" I use the ise12.1 suite ,when I open the xps , how I can do to solve the problem? |
ISE和XPS环境变量,即XILINX和XILINX_EDK应指向相同的版本。
确保这一点得到照顾...... 您还可以获取/运行位于Xilinx / 12.1 / ISE_DS文件夹中的settings32 | 64.bat或sh文件。 谢谢, PK 谢谢,-PK 以上来自于谷歌翻译 以下为原文 The ISE and XPS Environmental Variables that is, XILINX and XILINX_EDK should point to the same version. Make sure that this is taken care... You can also source/run settings32|64.bat or sh file which is located in Xilinx/12.1/ISE_DS folder. Thanks, PK Thanks, -PK |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2448浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 10:01 , Processed in 1.332738 second(s), Total 78, Slave 62 queries .
