你好,
我正在考虑将我的应用程序的一些校准数据存储到FLASH存储器中,因为我的EEPROM空间非常有价值,而且我无法保留任何数据。校准数据只能写入一次(在设备第一次上电时),然后每次上电时都会读取。 做这种事情的好方法是什么?我可以“保留”一些FLASH,以便编译器不会将该特定位置用于主程序吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hello, I'm looking into storing some calibration data for my application into FLASH memory since my EEPROM space is very valuable and I cannot spare any of it. The cal data would only be written once (upon the first powerup of the device) and from then on would be read everytime on powerup. What is a good way of doing this sort of thing? Can I ''reserve'' some FLASH so that the compiler doesn't use that particular location(s) for the main program? Thanks |
是的,您可以为FLASH区域中的校准数据存储“预留”内存。您应该事先知道校准数据结构的大小,我建议保留32K闪存区域底部的存储器地址(32K校准数据大小)。您应该确保编译的代码不超过32K校准数据大小。编译后的代码按顺序存储,因此它不会使用最后的字节,除非编译的代码足够大以利用它。
以上来自于谷歌翻译 以下为原文 Yes, you can 'reserve' memory for your calibration data storage in the FLASH area. You should know in advance the size of your calibration data structure and I recommend to reserve the memory address at the bottom of the 32K flash area (32K-Calibration Data Size). You should make sure that your compiled code does not exceed 32K-Calibration Data Size. The compiled code is stored in sequence, therefore it does not utilize the last bytes unless your compiled code gets big enough to utilize it. |
嗨,
查看外设库,那里有一个例子。 马丁。 以上来自于谷歌翻译 以下为原文 Hi, Check out the peripheral libraries, there is an example in there. Martin. |
2898 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
342浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-6 13:51 , Processed in 1.615447 second(s), Total 79, Slave 63 queries .
