嗨我正在使用PNA-X N5247A和6英寸同轴电缆作为DUT进行时域变换,以获得带通脉冲响应。
正如预期的那样,我观察到第一次脉冲的幅度和延迟(标记1,请参见附件)是有意义的,基于我用作DUT的6英寸同轴电缆。 但是我看到了一些凸起(标记2,3,4,5),考虑到电缆的长度短,我无法解释。 我发现,当我将Kaiser窗口β值从6改为8时,这些凸起变得更加明显(请参见附件)。 什么可能是这些颠簸的来源? 我的应用需要高动态范围,因此我的问题。 谢谢! 以上来自于谷歌翻译 以下为原文 Hi I am performing a time-domain transform using PNA-X N5247A with a 6-inch coax cable as DUT to obtain the band-pass impulse response. As expected I observe that the magnitude and delay of the first impulse (Marker 1, please see attached document) makes sense, based on the 6-inch coax I used as DUT. However I see certain bumps (Markers 2,3, 4, 5) which I am unable to explain considering the short length of the cable. Rather than a uniform roll-off, I see that these bumps become more pronounced when I change the Kaiser window beta value from 6 to 8 (please see attached document). What could be the source of these bumps? My application requires high dynamic range hence my question. Thanks! 附件
这些是从电缆的连接中重新反射在主瓣处通过的信号从输出连接器反射回来,从输入连接器重新反射并在第一次反射时出现3倍。
KB6情况下的常见波纹和KB8情况当然是滤波器通常预期的旁瓣。 编辑:对不起,我想念了x轴。 这些额外的涟漪可能来自测试端口电缆,如果它们大约每个1米。编辑:Dr_joel于2014年11月19日下午12:05 以上来自于谷歌翻译 以下为原文 Those are re-reflection from the cable's connections The signal that passes through at the main lobe reflects off the output connector, re-reflects off the input connector and comes out a 3x the time of the first reflection. The common ripples in the KB6 case and KB8 case are of course the normally expected side lobes of the filter. edit: Sorry, I missread the x-axis. Those extra ripples might be rather from the test port cables, if they are about 1 meter each. Edited by: Dr_joel on Nov 19, 2014 12:05 PM |
1360 浏览 0 评论
2409 浏览 1 评论
2245 浏览 1 评论
2095 浏览 5 评论
2990 浏览 3 评论
1347浏览 1评论
807浏览 0评论
1129浏览 0评论
1361浏览 0评论
GMT+8, 2025-2-9 14:05 , Processed in 1.296856 second(s), Total 77, Slave 61 queries .
