我需要拿起一个ICD3与PIC32 MZ使用。我听说ICD4速度更快。是否有足够的bug解决了,我应该得到ICD4代替?
以上来自于百度翻译 以下为原文 I need to Pickup an ICD3 for use with a PIC32MZ. I hear the ICD4 is Faster. Does it have enough of the Bugs worked out the I should get the ICD4 instead? |
3个回答
我不能为PIC32说话,但我的ICD4大多没有使用,因为每一个PIC16 / 18/24我尝试使用它有一个“黄色点”在MPLAB X 4.05。
以上来自于百度翻译 以下为原文 I can't speak for the PIC32, but my ICD4 mostly goes unused because every PIC16/18/24 I try to use it with has a "yellow dot" in MPLAB X 4.05. |
我喜欢我的真正的冰。我一直在认真考虑Segger。
以上来自于百度翻译 以下为原文 I like my Real ICE. I have been giving serious thought about a Segger though |
到目前为止,我的ICD4与我的PIC32 MZ2048 EFM144工作良好。有黄色点,因为它在威廉希尔官方网站
上没有得到完全支持,但是它仍然在IDE V4.05和调试和程序中很好地在IDE V4.05中进行编程。我还对DSPIC30F6012A进行了测试,并且它看起来也很好,尽管黄色点没有完全认证。RTD。调试不起作用,但错误指向我可能没有正确配置新的ICD4设置。在项目属性中,我必须告诉它我的PGC和PGD设置和拉/上拉/下降是什么。(我还没有广泛涉足它。)
以上来自于百度翻译 以下为原文 So far, my ICD4 works fine with my PIC32MZ2048EFM144. There is the yellow dot because it isn't technically fully supported, but it still programs fine in the IPE v4.05 and debugs & programs fine in the IDE v4.05. I've also tested against the dsPIC30F6012A and it appears to be good there too, despite the yellow dot of not being fully certified supported. The debugging isn't working, but the error is pointing to me probably not having my new icd4 settings configured properly. In the project properties I have to tell it what my pgc and pgd settings and pull/up pull/downs are. (I haven't played with it extensively yet.) |
5403 浏览 9 评论
2112 浏览 8 评论
2012 浏览 10 评论
3286 浏览 3 评论
2324 浏览 5 评论
901浏览 1评论
783浏览 1评论
722浏览 1评论
782浏览 0评论
675浏览 0评论
GMT+8, 2025-3-20 01:29 , Processed in 1.299026 second(s), Total 81, Slave 65 queries .
